Trying to bind my MX400 Mouse's forward and backward buttons inside of games. I've been using the Setpoint tool, tried binding them to keys on the keyboard with no success.
    President:
  • 2,712 Answers
Try setting the buttons to "generic" in SetPoint and then assign fuctions via the game options.
From Logitech Knowledge Base:
The information in this article applies to the following products:
All Logitech Mice
Logitech SetPoint
Cause:
Most games that support a mouse will give you options to program or assign specific functions to various buttons on the mouse. These games normally look for generic mouse buttons when attempting to bind the mouse buttons to a game function. If the button is set to another function in SetPoint (such as Universal Scroll, Back, Forward, etc), the game may not see the mouse button as available to bind. This mainly affects buttons 3, 4, and 5.
Solution:
To resolve this issue, set the button you wish to program to a generic value in SetPoint. The following values should be used if you are having problems binding buttons in games.
Mouse Button 3 (The Middle Button/Scroll Wheel):
In SetPoint, assign this button as Middle Button or Generic Button.
Note for MX Revolution users: You must disable Logitech Smart Shift Technology or the Middle Button option will not be available in SetPoint.
Mouse Buttons 4 and 5 (Normally the thumb buttons):
In SetPoint, assign the thumb button(s) as Generic Button. Note that these buttons will still work in most browsers for forward and back. It is not necessary to assign these buttons to Forward and Back in SetPoint for this functionality.
Posted on May 15, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
How do I slow down a logitech M510 mouse? I have it as slow as it can go using control panel mouse settings but it is still too fast
The software Mr. Maitia referred to is called Setpoint, and it's the key to getting full use out of your 510, or any other Logitech mouse/keyboard/etc. product. All versions of the Setpoint software and drivers for Logitech products are available for free download at the Logitech support website. Here's the link: Logitech Support
Sep 02, 2013 | Logitech M510 Wireless Mouse
Tip
Medal of Honor Airborne key binding
To bind cheats you'll need to edit the DefaultInput.ini found in "C:\Program Files\Electronic Arts\Medal of Honor Airborne\UnrealEngine3\MOHAGame\Config" folder. Open the file in notepad and scroll down till you find "[Engine.PlayerInput]" and add:
.Bindings=(Name="K",Command="upgradeweapon")
.Bindings=(Name="L",Command="ghost")
.Bindings=(Name="N",Command="slomo 1")
.Bindings=(Name="M",Command="slomo .3")
Trust me these are all the cheats you'll need to finish the game. If you need to add more just bind in any other letter and the corresponding cheats. Just make sure that the key that your a binding is not being used by any other commands. Remember to backup the original .ini file first before modifying.
on Dec 15, 2009 | Video Game Consoles & Games
Ignition locked
The ignition lock cylinder tumblers get in a bind all the time on GM vehicles. It probably has little to do with inseting the wrong key. Try inserting the correct key and "jiggle" the key in the lock. You may have to jiggle it up and down and rotate (or try to rotate) the lock cylinder forward and backward. It will probably work just fine if you can wiggle it with just the right combination. If not, you may have a damaged lock cylinder and you will have to replace it. - most likely nothing you did....I change at least two or three of these things every week...VERY COMMON.
Nov 26, 2011 | 2006 Chevrolet Malibu
Shifter lever won't return to the " center " position always. The problem is intermittent and seems to occur more in the heat. I've heard there may be something binding the mechanism....
Follow the shifter reach rod that runs from the shift lever back to a short lever on the transmission. Take the nut off and take the rod loose from this short lever. Then, move the forward like you are going to shift into low gear but don't actually shift the transmission into gear. Feel for the spring tension. Then, move the lever backwards and feel for the spring tension there. Check the shift lever and the reach rod for binding. If you don't feel the spring tension trying to return the lever back to the center, it's likely that the shifter pawl return spring is broken. This spring is what returns the shifter lever back to 'center". But,the temperature of the transmission will not change this. If the spring is broken, it's broken cold or hot. If the spring is good and there is not bind in the linkage, the problem may be in the shifter cam mechanism inside the transmission. Either way, this is an internal issue in the transmission.
Good Luck
steve
Aug 20, 2011 | 2006 Harley Davidson FLSTNI Softail Deluxe
MY ignition want turn forward or backward so i can get the lock pushed in to pull the tumbler out any solutions?
will try to assist you.are you parked on a hill? or parked somewhere as to out the transmission in a "bind"? try turning your key switch to the on position and at the same time you're attempting to turn the key to on,wiggle the steering wheel back and forth,like you're turning to left or right. sometimes the steering lock binds when the cars parked on a hill,or parked against a curb.try to turn the steering wheel to the left,while turning the key to "on" some times rocking the car back and forth will free up the locked steering column.while turning the key to the "start" position of course. try this and if this does'nt help you" please repost your question to fixya.com. thank you for seeking out fixya.com we look forward to assisting you in your future automotive,or household questions with appliances,or just about anything.there are experts ready to assist you 24/7
Apr 11, 2011 | 2001 Chevrolet Cavalier
Right Click Defected in-game
try switching the right click to another button using setpoint. if the button works perfect then it is the micro switch for the right click contact logitech. if it drops turn off setpoint and try the regular right click if that drops just may be a glitch in the game. check for mouse controls in the game to tune the mouse.
Jul 17, 2009 | Logitech G5
Snowbard bindings adjustment
"With everyday use, the screws, nuts and bolts that hold the highest stress areas together tend to loosen up. Consequently, they need to be tightened regularly to ensure that a strap doesn't fall off and get lost. However, not every Mountain Resort provides tool stations, so it's important to have a Snowboard Tool within reach (preferably in your pocket) at all times. Remember, a snowboard tool is a small investment that will definitely pay off over years of riding. Also, with the standardized insert pattern of snowboards, and with the built-in adjustment capacity in most Bindings, Mounting and Adjusting Bindings has become simple quite a simple task. To be able to do this, make sure you have a screwdriver and a wrench or two. Also, it would be a plus if you have some basic knowledge about the stance width, stance location and stance angle. The distance between your front and rear foot is the Stance Width. The basic stance width is roughly the length of your shoulder-width apart (about 30 per cent of your height). The location of the center point between your Bindings relative to the center of the snowboard is the Stance Location. Conversely, the angle of the Bindings across the snowboard's longitudinal axis, wherein zero degrees represents a line that is perpendicular to the snowboard's length, is the Stance Angle. * Forward Lean For starters, check your board's Forward Lean. The forward lean is the amount of forward angle on the highback support. For more leverage and more responsive heelside turning, add more forward lean. By adding forward lean, you also force your knees to bend, consequently ensuring a good riding stance. Still, too much forward lean makes your knee bend too much. Over bending your knees put pressure on your quadriceps muscles and reduces your ability to turn easily. So don't overdo it. You can usually adjust the forward lean in soft-boot Bindings by changing the position of a plastic stay behind the highback. * Rotating the Highbacks You can easily rotate your Bindings' Highbacks if your bindings have slots on the hinges where the highbacks are fastened to the binding's baseplate. To make your heelside turning more responsive than when it is angled along with the baseplate, adjust your Bindings in parallel with the Snowboard's Heel Side Edge. You can do this by loosening the bolts and rotating the highbacks. * Adjusting Strap Position Generally, this involves unscrewing the straps from the baseplate and moving them forward or backward on the Bindings. To improve control, move the straps higher up on the foot. Conversely, move them down lower to increase flexibility. Make sure that the toe strap is resting around the base of your toes and is securely holding down the tip of the boot. Shorten your straps if you find yourself pulling on them for a snug fit. You can do this by fastening the straps to the baseplate further along the length of the strap. Most straps already have extra holes for this adjustment."
Dec 01, 2008 | Flow M9 Snowboard Binding
G5 sensitivity issue in TF2
Choosing "Setpoint Implementation" instead of "OS Implementation" in Setpoint (the last tab) did it for me.
Oct 25, 2008 | Logitech G5
Gears of War for Vista and Logitech Rumblepad 2 directional issues (fwd/rev)....
There is a way to fix it: go into your control panel under Game controllers, select your logitech cordless rumblepad 2 and hit
properties -> settings -> Enable Swap Mode -> close -> ok
Now start Gears of War and go into the options menu under controls for the controller.
Invert Axis = yes
Joystick Mode = Left-handed
This fixes the problem with the joysticks, but there is still a button fix that needs to happen. operations for buttons 2&3 are swapped, same thing with buttons 1&4, 5&7 and 6&8. I don't how to fix this problem yet.
Dec 30, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Gears of war problem
Simple fix for forward-back movement axis inversion:
In "My Documents\My Games\Gears of *** for Windows\***Game\Config", edit the file "***Input.ini". At the very top, under the section "[Engine.PlayerInput]", change your MoveForwardSpeed to a negative number, like this:
MoveForwardSpeed=-1200
Note that I only play offline, and this setting in this file works great for me with Logitech Rumblepad 2 (although all of the other buttons are still a little off, but that I can live with). I tried every other reference to forward-backward movement and the left Y axis in this file, as well as "<installdir>\Engine\Config\BaseInput.ini" and "<installdir>\***Game\Config\DefaultInput.ini", so don't bother with those...
Dec 08, 2007 | Logitech Rumblepad 2 Game Pad
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
