Question about Durabrand DWT2405 24" TV
Remote W/out any problems before the T.V. would not go pass Ch. 24. All you get after 24 is snow. i have 3 other TVs in the house all on trhe same cable and they are doing find. Please give me some help.
  • lnraker Aug 21, 2008
    Tuner will not go past channel 69. Have tried auto programming channels, add/delete channels with no luck.
You might have to go to menu and add the channel to your television.
Posted on Aug 08, 2008
Samsung TV
Based on the information you described you may have a tuner
circuit problem or power intermitent faikure fron the power supply module.
Nov 02, 2012 | Samsung Televison & Video
Hello,I have purchased a digital converter to connect to my tv to receive local stations,My question is,What do i need to connect all 4 tv's that I have to the converter? or Do i need a converter for...
The converter has only one tuner, this means it can only tune one station or channel at a time. The output of the converter is usually a single coaxial cable jack. The output is generally a user selected channel - often Ch 3 or Ch 4. When you connect the output of the converter to the antenna input of the TV, you set the TV channel to match the setting on the converter (again, Ch 3 or Ch 4).
You could install an amplified splitter to split the output of the converter and run a cable from each TV to the splitter, more on this amplified splitter, later. Set all the TV's to the same channel as the converter output (Ch 3 or Ch 4) and you would be able to watch whatever the converter is tuned to. This means ALL the TV sets must watch the same channel. What is showing on one will be shown on all. This may not be a problem if you live alone and own 4 TVs. You could simply turn one TV off when leaving a room and turn on another when entering a new room. This will be a problem if there are two or more people in the house that wish to watch different programs at the same time. To accommodate everyone, you would need as many converters as there are different programs that are to be watched on different TVs at the same time - 4 would be a good choice to provide the greatest flexibility of tuning for every TV.. You would simply install the additional converters on the other TVs just as you did with the first TV.
If you wish to use a splitter to divide the output of the converter to several different TVs (or have a single antenna and want to send the signal from it to several TVs for that matter), an amplified splitter is highly recommended. A standard splitter only divides the signal and has no provisions to boost the signal from the antenna. The more ways a signal is split, the less signal there is to supply to the TV sets. The result is a snowy picture. An amplified splitter not only splits the signal the way a standard, non-amplified splitter does, but also boosts the signal from the antenna to each TV. This provides a much stronger signal to the TV which results in a better picture. Pick an amplified splitter that has enough output jacks (based on the number of TVs you wish to connect).
I hope this helps and good luck!
Sep 13, 2011 | Televison & Video
Connecting TV to VCR but all I get is snow o n the TV
Tune your TV to Ch 3 or 4.If it has a input button on the set or remote press it and then choose video that works with the VCR.
May 26, 2011 | Samsung TXJ2554 TV
Hi, I have a problem finding a code for my motorola DCX3200 with my universal remote control(cox.) All the other televisions in the house worked, but I can't get this one to respond at all. I have an LCD...
Here is the user guide for the Motorola DCX3200 in PDF format just in case you need it.
Now then here are some Codes for your Cox Universal remote. I understand you have tried some already but just in case you missed any.
Samsung 0060, 0030, 0178, 0019, 0056, 0032
Also give this a try.
  1. Turn on the TV, VCR, DVD, or entertainment center that you want the remote control to control.
  2. On the remote control, press the appropriate mode button for the device once.
    Television TV
    Stereo amplifier or receiver AUX
    DVD, PVR, VCR DVD
  3. Press and hold the SETUP button until the selected mode button blinks twice, then release the SETUP button.
  4. Using the number keys, enter 9 - 9 - 1.
    Result: The selected mode button blinks twice.
  5. Aim the remote control at the device, and then press the POWER button once.
  6. Press the CH+ (or CH-) button one or more times until the device turns off.
    Notes:
    In search mode, the remote control sends IR codes from its library to the selected device, starting with the most popular code first.
    If, while pressing the CH+ button, you inadvertently pass the code, press the CH- button one or more times until the TV turns on.
  7. Press the SETUP button once to lock in the code.
  8. To search for codes for other devices, repeat steps 1 through 7.
Hope this helps, give me thumbs please!
Aug 23, 2010 | Televison & Video
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv has snow
First change the channel on the TV set to channel 3 or channel 4 to see if you see a menu from the Set Top Box. If so follow directions on the menu. If you don't see a menu on CH 3 or Ch 4, recheck your wiring. For more help, check the FCC website at http://www.fcc.gov/cgb/consumerfacts/setup-converterbox.html. If you are still needing help, dial the phone number listed at the bottom of the website (1-888-CALL-FCC (1-888-225-5322)) they can help and even have someone come help you make the connection at no cost to you.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
VCR Connection
If your vcr has an ant. in and out to tv coax type jacks the signal should pass through when the vcr is off or in tv mode. Make sure tv is on the output channel of the converter box(usually ch 3 or 4). If your vcr is different please give more info.
May 14, 2008 | Insignia Digital-to-Analog Converter for...
Panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
Nov 11, 2007 | Televison & Video
Durabrand DWT2405 24" TV Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
