Question about Roadmaster 10 Dual Deck Trike
How do I get replacement parts for a childs roadmaster tricycle. I am looking for the white pieces on the end of the front forks that hold the wheel on.
    New Friend:
Try to search on amazon. here: Give your little one the ultimate holiday gift. Hope this was helpful. cheers
Posted on Nov 29, 2014
    New Friend:
Call 1-800-626-2811 they have just about anything for this tricycle. They are inexpensive, too.
Posted on Jun 28, 2013
Go here http://www.searspartsdirect.com/partsdirect/part-model/Roadmaster-Parts/Bicycle-accessory-Parts/Model-6702SR/0886/1303200/00040484/00001
Posted on Dec 06, 2010
Front pedals
Yes, you got the bolts too tight on the axle shaft. You have to "sets" of nuts, the inner and the outer. The inner nuts on the shaft, which go inside the fork, should be adjusted so the wheel is rolling freely, with just a tiny "slop". Now, you will need to figure out a way to tighten the outer nuts to hold the wheel on the fork without turning or moving the inner nuts! Some bicycle shops use specially thin wrenches.
Be blessed.
Aug 08, 2013 | Schwinn 12" Roadster Tricycle
I need a replacement pedal for the right side of a Roadmaster tricycle made in Olney, IL
Try calling - 800 - 626 - 2811. They helped me with hard to find parts for my tricycle. Very helpful and very inexpensive!
Jul 31, 2012 | Roadmaster 10 Dual Deck Trike
How to Replace front fork seals on Suzuki GSXR 1100 K model
Remove front wheel, brake calliper etc . Undo top and bottom yoke pinch bolts and slide out fork leg. Clamp chrome tube in a soft jawed vice and remove top nut carefully as it is under some load and will fly away, (but its not too much you can hold it with your hand). Tip out remaining oil slowly so as to not loose spacer on top of main fork spring. Clamp lower aluminium leg in vice by calliper mounts and remove allen screw in extreme end (if the wheel spindle was in you couldnt see it) This is the only part that might be a problem as the inner end may turn. An impact wrench may help or if not a simple broom handle shoved up the other end is often enough. Once this bolt is removed the leg will split. Now lever out the dust cover to reveal the wire circlip holding in the fork seal. Remove the clip and lever out carefully the old fork seal. Fit new seal using a large socket and mallet or something similar and reassemble in reverse order, not forgetting to add correct amount of new fork oil.
Jun 30, 2012 | 1989 Suzuki GSX 400 XS Impulse
Need pedal for roadmaster tricycle with keeper ring. was not available at searspartsdirect.com.
this ia question - does anyone know hoe to remove the pedals from a roadmaster tricycle ?
May 22, 2011 | Roadmaster 10 Dual Deck Trike
I recently bought an Amloid My First Mini Cycle for my son. I was only given on packet of assembly intructions for the fork and front wheel of the cycle. Once you put that together the instructions say...
You need to hammer the cap on. The tube with open ends fits over the cap and lets you hammer it on. To make it work, you need something to hold the other end, like a block of wood, or I found a hockey puck worked perfectly. Assemble the rear wheels, then turn the cycle on its side with the cap end of the axle down. Put it on the block of wood or the puck, and then hammer on the cap with the help of the tube. Now if you can help me get the handlebars on, I'd be eternally grateful. Problem is the spacers seem to be too big to allow the fork into the slot in the handlebars, and without them, there is nothing to screw into to hold the handlebars.
Apr 30, 2011 | Toys
I have a roadmaster tricycle it was bought in the 90's I need a new seat for it. Where can I find one? Thanks Becky
Sep 07, 2010 | Schwinn 12" Roadster Tricycle
Front strut replacement
Yea, you gotta take the brakes off, the rotor, the axle nut, then you should be able to pry the spindle down far enough to remove the strut.
May 04, 2010 | 1997 Acura CL
Need replacement part
I think you may need a new bike.
Apr 12, 2009 | Cycling
Roadmaster 10 Dual Deck Trike Logo
3,785 people viewed this question
Top Roadmaster Cycling Experts
ptpumpman
Ed Everest
Ed Everest
dante
Are you a Roadmaster Cycling Expert? Answer questions, earn points and help others
