Question about Casio ClassPad 300 Calculator
How do i perform standard deviation on the calculator?
  • Casio Master
  • 8,073 Answers
Turn ClassPad ON.
Press [MENU]
Find the STATISTICS application and tap its icon.
Enter your data in one column (L1) and frequency values in List 2.
If all frequencies are equal to 1, no need to enter them in L2.
After you finish entering the data, Tap the CALC menu at the top of screen.
Select One-Variable (or two variables if you want regressions) and tap the OK button. You are given the opportunity to select the data list and the frequency list, if any.
Validate your choices. and tap OK.
Statistical values are displayed. The display runs more than one screen. Use the downHow do i perform standard - 63683fa.jpgroll.
Posted on Sep 18, 2010
  • k24674 Nov 26, 2010
    What is wrong? Doesn't this answer completely and fully your question, and then some?
I have 50 data points for which i need to find standard deviation on a classpad 330 , is there any quicker way to calculate than minusing the mean from every data point?
Here is one technique I used on the TI84Plus.
Create two lists list1(50) and list2(50) of equal dimension (same length)
You will have to find how to do it on ClassPad.
Fill list2 with zeros
Fill list1 with your data.
Sort the list in ascending order (if it is not sorted)
Do standard deviation calculation on list1 (or calculate the average)
The mean of the data is in a special variable (xbar)
From the command line using the list syntax calculate abs(list1-xbar) and store results in list2, overwiting the zeros.
Perform standard deviation on the new list2. You will get the mean deviation from the mean in the variable xbar.
A simple request from you. Can you please not use MINUS as a verb? By doing so you are propagating incorrect usage. There is a short and correct way to express the operation: to add.
May 05, 2012 | Casio ClassPad 300 Calculator
Which button do I use for the square root button? I have to perform math problems on... geometric mean population standard deviation sample standard deviation
The square root button is two up from the 9 key, just to the left of the divide key. To calculate the square root of 2, for example, press 2 square-root =
Jun 10, 2011 | Texas Instruments TI-30XA Calculator
Does this calculator comes with a standard deviation or population standard deviation button
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
Apr 02, 2010 | Texas Instruments TI-30XA Calculator
How do you enter frequencies for finding standard deviation? For example, Frequency=50, total of X or raw scores = 366.5. Summation of X squared =2836.39. What is standard deviation? How do you enter the...
I am afraid I do not understand. The frequency of a PARTICULAR score is the number of times that particular value occurs in the data. It is not the number of data.
Ex: the data are:
4, 6, 5, 4, 4, 8, 9, 3, 3, 6, 7
Frequency of (3) =2
Frequency of (4)= 3
Frequency of (5) =1
Frequency of (6)= 2
Frequency of (7)=1
Frequency of (8)=1
Frequency of (9)=1
Number of data =11 (n=11)
You compute the mean M
M= (2x3 + 3x4 +1x5 +2x6+1x7+1x8+1x9) /11 =5.363636..
As you can see, if a term is not repeated it is multiplied by 1 (its frequency is one). Value 3 occurs twice (hence 2x3); value 4 occurs 3 times (3x4), etc.
To calculate by hand the sum of squares
3: (3-5.3636)^2 + (3-5.3636)^2 .................... = 2x(3-5.3636)^2
4: (4-5.3636)^2 + (4-5.3636)^2 +(4-5.3636)^2 = 3x(4-5.3636)^2
5: (5-5.3636)^2 ...................................... .= 1x(5-5.3636)^2
6: (6-5.3636)^2 +(6-5.3636)^2......................= 2x(6-5.3636)^2
7: (7-5.3636)^2.......................................... .=1x(7-5.3636)^2
8: (8-5.3636)^2......................................... ..=1x(8-5.3636)^2
9
: (9-5.3636)^2......................................... ..=1x(9-5.3636)^2
If I have not made a mistake the sum of squares is 40.5454
Standard Deviation
The standard formula above gives s= square root (40.5454/10) =2.01
Population Standard Deviation
The population Standard deviation above is S= square root (40.5454/11) =1.9198
So if you perform the calculation with the calculator the only times you need to enter the frequency is for repeated terms. When you have to enter 6 above, its frequency is 2 you proceed as follows
6 [2nd][FRQ] 2 [Sigma+]
Once you entered the raw scores, the calculator does the rest.
Hope it helps.
Nov 06, 2009 | Texas Instruments TI-30XA Calculator
Is there a formula for standard deviation problems
Of course there are formulas for those calculations. You find them in books on statistics. Do not worry, the calculator has been programmed to use them. All you have to do is learn how to get the calculator to give you the results.
If you still want to see the formulas with your very eyes, I suggest you go to the local library, ask a math teacher, an accountant, or launch a Google search for them.
Hope it helps.
Aug 05, 2009 | Casio fx-300ES Calculator
Standard Deviation
Press 2ND [CSR] to clear the stat data.
For each data point, enter the number followed by SIGMA+
If you have grouped data, enter the number followed by 2ND [FRQ] followed by the frequency then SIGMA+
Press 2ND [sigma x n] for the population standard deviation or 2ND [sigma x n-1] for the sample standard deviation.
May 25, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Standard Deviation
I want to calculate a standard deviation on BA II plus
Apr 23, 2008 | Texas Instruments BA-II Plus Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Standard deviation
StdDev( {1,2,3,4,5,6,7,8,9,10} )
with your list inside the curly braces.
Nov 10, 2007 | Texas Instruments TI-30 XIIS Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Casio ClassPad 300 Calculator Logo
3,161 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
