Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse 32" LCD TV
My TV has a normal picture for about a half hour after it's turned on, then it shuts the video while the sound and power remain on. Turning it off will restore the video, but it shuts down again soon after.
Keeping a fan going behind the TV keeps the video on, so I figure it's an overheating problem. What's the fix?
  • Anonymous Dec 10, 2008
    After approx 2 years I'm having the same issue. Go Westinghouse. I figured it's the board overheating. Anyone know where to order it?
  • Anonymous Mar 20, 2014
    if I shut it off for a time it will return to normal
I had nearly exactly the same problem. Like you, I noted that keeping a fan going solves the problem, so i just went out and found a really small and silent fan that I could attach to the back of the tv. Since my TV had a USB port, I found a $10 USB-powered computer fan and attached it there. Full story at http://bottleworld.net/?p=193 . Hope that helps.
Posted on Nov 05, 2008
Needs main board, this main board has been on back order since FEB
Posted on May 29, 2008
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
My Westinghouse HDTV LCD 32"
LCD circuits overheated shut down the video. Leave the TV on standby for a week or more to see if the ccfl lamps come back on. You may need service.
Dec 18, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse 32 lcd tv - no picture no sound - set comes on power light stays on logo comes up but then screen goes black and no sound either - would this be a bad power or bad main board?
Reset the tv and the cable or satalite boxes,replug it back an hour later let the tv reset it self back to factory setting and the boxes upgrade it software.The tv should work now.Not,than yes.It the Tuner main board.
Sep 17, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
Westinghouse TV no picture just sound. 32
one or 2 caps in the power supply they will be domed from venting
Sep 16, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
I have a 32" TV/DVD combo westinghouse LCD TV. When I turn the TV on I get no picture. There is sound. DVD player does not show picture either, I have sound but no picture.
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse ltv32w6hd power supply
One of two symptoms on this model (LTV-32W6HD) Blue light comes on but cannot shut off. No picture; OR No picture but sound is OK. 1: In both cases replace ALL the electrolytic capacitors onthe output side of the power supply. This should get the power switch to worknormally. 2: Replace the small tiny wee little tiny small 2.0A fuse onthe inverter board labeled F1. This is the small black fuse, not the slightly bigger whiteones labeled F2 and F3.Ta Da...all fixed.
Nov 19, 2008 | Westinghouse LTV32W6HD 32 in. LCD...
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 32 in LCD TV
I have had this problem now for about six months with my Niko OPT-3211W. After replacing the Inverter card, VIT70002.00 as suggested nothing changed. I then read that it may be a couple of capacitors in the power supply, but I do not have the skills needed to replace them, nor do I want to pay to fix it. The solution is simple... turn on the TV and wait two to five minutes, then turn off the main power. I suggest using a power strip. Then turn the power back on in two to five seconds. The TV will come back on and it works great from then on. I thought that it was a freak thing, but it keeps working.
Jun 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Power up problems
Does anyone know what the part number for this elucid power supply would be? My TV is doing the same thing, so I'm trying to find one so I can swap it out.
Apr 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
388 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
