Question about Samsung LW26A33W 26 in. HD-Ready LCD Television
Sound My LW26A33W Samsung TV does not give the sound from the ariel. It works fine from the Scart connection. i.e. The DVD sound is fine. However although the picture is perfect from the ariel, the sound does not exist..... please help
  • Samsung Master
  • 520 Answers
First I would check the cable from the ariel to the tv and all connections in between.
Posted on May 15, 2008
No picture only black screen, the sound is fine
I know it may seem simple but try just double checking all ports try pulling things like scart sockets or ariels out slowly as some may have a slightly loose connection (not a big problem but you may need to blue tack the scart in) once all out if no luck try pushing everything in again. more info could help me to give you a more detailed answer (like what you want a picture from e.g. Virgin box, DVD player or something else entirely. And how it is connected to your TV) You could try retuning the device if it's freeview or set top box (or such like) but I suggest giving me more info before retuning.
Mar 06, 2012 | Televison & Video
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
Cant get a picture on tv using dvd but can get sound Samaung dvdR120
I assume you're using a Scart connection between the DVD & the TV. Try re-fitting the scart into both the DVD & TV, it is common for the scart cable to become slack & will give you this symptom.
Jul 12, 2009 | Samsung DVDR120 DVD Recorder
No sound coming through system when tv on but works fine with dvd
you need to link the tv sound out to the aux/tv in on the dvd. Or if the scart connecters on the rear of the tv have a 2 way arrow, showing input and output on the one scart socket (usually scart 2) and the dvd supports scart sound in use that.
Then select the source on the dvd that coresponds to the conecter used.
Jun 15, 2009 | Samsung 1000W 5.1-Ch. Home Theater System...
Can see no way of connection to terrestrial TV, no scart connection?
easy dose it have rf out? or phono out if you have phono out buy a phono to scart lead to conect
Apr 28, 2009 | Televison & Video
Sound but no picture on either SCART socket inputs
open the tv and check for dry joints on the jacks of AVS, if no dry joint is found
the ariel in put is different from AV inputs
change the AV in IC. AT THE W/SHOP
Apr 25, 2009 | Goodmans 257NS 20" TV
Samsung home cinama
Most likley your scart cable is the culprit, check whether the scart cable is the AV I/O type. And also better check the audio settings of the DVD player. Hope u hook up the speakers correctly. Cheers, Rifaa
Sep 04, 2007 | Samsung HT-Q100 System
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound through TV
In case you connect the System to a TV set using the Scart Connector, only the video signal is terminated, Audio is actually not wired inside the SB100 Scart connector.
Sound will only be amplified through the system itself (through the satelites and Sub) it can not be utilized as a stand-alone DVD player.
So after connecting your surround speakers the problem will be solved
Apr 30, 2007 | Sony DAV-SB100 System
Samsung LW26A33W 26 in. HD-Ready LCD Television Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
