I need a wiring diagram for a Dayton 5mfd oval 370vac hvac capacitor.
  •  Christopher a Martin
    Hello Please give wire colors from fan motor.
ranger25
  • 72 Answers
SOURCE: dayton heater/ need wiring diagram /
What's the model number?
Posted on Jan 28, 2008
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
SOURCE: Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
You do.I too have a Dayton replacement motor.Works great.
Posted on Jun 06, 2009
  • 340 Answers
SOURCE: I need the 20+10uf/370vac 60hz capacitor for my
try to google it. Tom
Posted on Jun 23, 2009
SOURCE: Yes I need the wiring diagram for Dayton model
wiring Mistral Speed Regulator Model MCF48D/6OD 220-240V
Posted on Sep 07, 2009
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Capacitor compatibility help
it will work just fine. the mfd are your only concern on residential units.
Sep 04, 2012 | Bryant 3.5 Ton R22 12 Seer Condenser Only/...
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
I need to replace the capacitor for a flowmaster xp2e 230v model 05825001-2. old one says 35UF +/- 6% 370VAC. is this a run capacitor? i have found replacement capacitors online that say (35) 370VAC, is...
Yes, that is a run capacitor. You will also need to clarify oval or round design.
You should take the old one in to a local electric motor repair shop if it is not obvious it is blown. Even if it is, their will be other issues that caused the capacitor to fail in the first place. You will want to try to identify those and fix them as well or you will be replacing the capacitor again soon.
John
Dec 05, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
How do i replace the start capacitor on my furnace in the attic?
There actually is no start capacitor in the furnace, but there is usually a run capacitor. The run capacitor is mounted on the blower housing. Turn the power off to the furnace and remove the blower door. Look back at the actual blower motor and follow at least one brown wire to a metalic oval. That metalic oval is the capacitor. Remove the wires and make a note of how it is wired and install a new capacitor of the same microfarad value. The microfarad value is marked something like 5mfd or 5uF (it may be 3, 5, 7.5, 10, or 15 microfarads. Make sure to use the right one or you can cause failure to the motor.
Feb 17, 2010 | Storkcraft Baby Lennox Stages Crib
Looking for an MFD for a carrier with serial # G753756 If I'm correct, this unit is from june of 1975. Is this correct?
If you are talking about a Capacitor (Round or Oval) it wont matter what make or year the unit is,.,,.,.simply match the MFD rating on the old capacitor with the new one....ie:5MFD , 35/5 MFD....etc
Oct 21, 2009 | Heating & Cooling
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
