I cant uninstall df5serv.exe . how to remove it. describe me
  • 61 Answers
This is a windows Operating system process. Kindly Go through this below link.
http://www.file.net/process/df5serv.exe.html
Hope this was helpful
Cheers!!! Have a nice day!!!
Posted on Sep 14, 2010
I cant run cricket.exe in my windows 7 ultimate ..im using sony vaio laptop it is giving error like"problem cause stop working " please give me solution as early as possible
try to reinstall the software but first you need to remove it completely. You can use revo uninstaller to completely remove the application and its safe to use. After uninstalling the application, restart the laptop then reinstall cricket. hope this helps
Feb 09, 2013 | Computers & Internet
Describe your ahc.exe photoshop error Problem
Delete Adobe folder and reinstall it.. the AHC.exe error will not let you uninstall or perform repair reinstall... so thats why you need to delete the folder first.
Apr 16, 2011 | Adobe Photoshop CS2 for PC
I am trying to uninstall webroot spysweeper with antivirus but cant find it to remove it, what should i do?
Under normal circumstances, like any other Anti-Malware software, Webroot will protect itself. You cannot randomly shut down its service. You cannot use most external uninstallers.
Always try to uninstall it using Add & Remove Programs first (on XP) or Programs and Features (In Vista and 7), or the uninstall link in All Programs on your start menu.
If you are not able to find it in any of these places, get the official cleanup utility from Webroot directly at:
http://download.webroot.com/SSCCleanup.exe
This utility is made to cleanly shut down and clean up Webroot SpySweeper, Antivirus, and Internet Security Essentials and will even remove itself when it's done.
Dec 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
How to uninstall the norton product
please go ahead and download www.symantec.com/nrt ,tool and run this tools and after running this tool please restart the computer and it will remove the norton products completely out of your computer
thanks....
Nov 18, 2009 | Symantec Norton AntiVirus 2002 8.0 for PC
While installing deep freeze my system rebooted and then some error happened. following which it kept on rebooting couple of times, so i used system restore setting to run it. when the system recovered i...
This is the coomon error of the deep freeze . I you can not access deep freeze then download deep unfreezer from http://www.brothersoft.com/d.php?soft_id=171878&url=http%3A%2F%2Fusfiles.brothersoft.com%2Futilities%2Fmiscellaneous%2Funfreeze_quicksetup.exe
Then disable deep freeze with out password after that use the same istaller to unistall the deep freeze which you have used to install .
Nov 02, 2009 | Computers & Internet
How to uninstall deep freeze v6?
I believe DF5Serv.exe is running as a service. It also appears that it resists attempts to remove it.
I'm going to give you a couple of ways to remove this.
  1. Boot the computer, pressing [F8] as the initial Windows splash screen appears. From the ensuing menu choose "Safe Mode - command prompt only"
  2. Once booted and logged in, type "sc delete DF5Serv" and press enter.
  3. The command should echo back a number of lines. The one labeled "STATE" should tell you if the remove worked.
  1. If the message above indicates that the service didn't uninstall, type "msconfig" and press enter. (You may need to type "\windows\pchealth\helpctr\binaries\msconfig")
  2. Here you can either click "Diagnostic Startup", or go to the \Services\ Tab and unselect "DF5Serv" from the services list. Click [OK].
  3. Allow msconfig to restart the computer and, once logged in - search for DF5Serv.exe and delete it.
  4. You will need to 'clean up' the mess by undoing the changes in msconfig and manually editting the registry (at your own risk!) to remove any keys referencing DF5Serv.
I hope this helps. Good Luck!
Jun 15, 2009 | Computers & Internet
Remove deep freeze
Try deleting it manually, go into safemode with cmd prompt only.
del c:\[filedir][filename]
it will induce an error next time it runs, but you can regedit.exe your way out of that one
Feb 27, 2009 | Compaq Armada M700 Notebook
How to uninstall deep freeze from your pc?
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
933 people viewed this question
David Payne
David Payne
