Question about Toshiba TDP-P6 Multimedia Projector
Picture cuts out after 3/4 minutes and goes into 'Searching' mode
  • Toshiba Master
  • 17,130 Answers
Could this be due to the lamp hours being down. Check to find out iff the lamp had burned out./become weak
Posted on Sep 14, 2010
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Turned tv on 2night had picture and sound for approx 3 minutes then tv turned itself off had 2 flashing red lights turned tv back on no picture or sound then turned itself off again
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Mar 16, 2011 | Sony Televison & Video
I turn the TV on. Then about 3 minutes later the picture goes out but the sound is fine. I turn the TV off, then back on. The picture returns only to cut off againg.This happens when viewing the in TV mode...
When picture goes away do you see the screen still emitting light or does it go completely blank?
Depending on the answer there are two possiblities:
if the screen goes completely blank then the problem is likely in the TV's inverter and more specifically very likely in some of the high-frequency transformers. Best solution there is replacement.
Unfortunately inverters are often on one board with power in smaller TVs.
if the screen is still emitting light albiet being blank then the problem is more likely in the main board and, less often, in a cable.
Main boards often overheat and ICs relying on soldering contact bonds of 1/10 sq.mm. start misbehaving in all kinds of ways , including like you describe.
There's no simple cure for that problem - usually it's cheaper to replace the whole board or even the whole TV than to troubleshoot it.
Perhaps not great news, but that's what I know about it.
Bobby
http://www.coppelltvrepair.com
Jan 23, 2010 | Toshiba 20HLV86 Television
My picture goes out about twenty minutes but the
I JUST BOUGHT A FLAT PANEL TV MYSELF AND DID SOME RESEARCH SAMAUNG AND SONY ARE YOUR BEST UNITS OUT THERE. I NEVER NEW THE AMOUNT OF HEAT THOSE FLAT PANELS GENERATE UNTILL I WENT SEARCHING FOR MY OWN AND WAS BRIEFED ABOUT THIS PROBLEM. MAKE SURE YOU HAVE PLENTY OF VENTALATION AT THE REAR OF THE TV, IT COULD BE OVER HEATING ,CAUSING THIS PROBLEM
Aug 10, 2009 | Polaroid Televison & Video
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Picture size
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Please read page 39 or in your manual page 38
Nov 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Picture won't stay on.
The problem is with the backlight inverter driver. It thinks that one of the CFL lamps is bad. I fixed mine by opening it up and cutting a track in the inverter board (with the power off!!). But you need to be a bit of a geek to undertake this fix. I you want more details email me at lmann1952@yahoo.com
Jul 24, 2008 | MegaVision Hyvision MV177 17" LCD Monitor
Continuous Channel Searching & Power Button Issues
What source are you using? If cable, you should only be able to pickup channel 3 or 4 if you're using the box. If there is no antenna, that would be the only other answer if the set checks out...accordianman
Mar 20, 2008 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Picture goes into multi coloured vertical lines
have a tech check your tv your problem is in the video circuit could be a cold solder or a component is damaged and need to be replaced.good luck.
Apr 15, 2007 | Philips 32PF7320A 32 in. LCD Television
Toshiba TDP-P6 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
