Question about Ricoh Aficio 2015 Copier
I have a problem RICOH Aficio 2018D A MULTIFUNCTIONAL DISPLAY ON ERROR I prevent my SC 500. How can I solve this problem?
  • Ricoh Master
  • 525 Answers
SC 500 : Main motor lock
Symptom:
A main motor lock signal is not
detected for more than 7 consecutive
checks (700 ms) after the main motor
starts to rotate, or the lock signal is not
checks during rotation after the last
signal
Possible Cause:
• Too much load on the drive
mechanism
• Main motor defective
Posted on Jan 22, 2011
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
My Ricoh afficio 2018d has error SC 551,what is the problem and how can i solve it
From what i understand this error is the pressure roller thermistor, this could be either dirty or faulty. it is recommended to replace the rear and middle one at the same time.
Below is a link to the service guide manual for your ricoh which should show you how to replace the thermistor or how to clean it.
http://www.printcopy.info/?l=en&mod=docs&brand=Ricoh&prefix=Aficio&gID=4754
Hope this helps.
May 05, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Error 500 ricoh 2018
sc 500 is the main motor error. replace the main motor at the back. it will solve the problem
Jan 04, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Printer side problem
Try by switching off and on the machine.
If every time you switch on the machine, SC824 re-appears, please replace the NVRAM on the controller board or the controller board itself.
Nov 17, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Error code 541
hi!!!!
may be the drum is damaged
try to clean it use dry tissue
or
repkaced the drum!!!
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2015 Copier Logo
611 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
