Question about Frigidaire Refrigerators
My frigidaire plhs237zab4 (side by side)stopped chilling today at first I thought it was my freezer but its both sides & a electric motor (sound) kicks in every 15 mins and relays off (click)
  • 145 Answers
Sounds like the compressor has locked up. Could be an exspensive repair. I would check your warranty you may have one that still has a sealed system warranty.
Posted on May 15, 2008
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
We have a side by side refigerator and it stopped making ice. I thought it may have been a dirty filter because I unscrewed it and there was ice surrounding the filter so I replaced it today. I am getting...
If the ice maker switch is in the on position then It sounds like the electric solenoid valve that controls the water flow to the ice maker has failed. Have it replaced and that should fix it. Hope this helps. Good luck.
Dec 02, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrig side not working
sounds like the circulating fan(evaporator)is wearing out, this problem is very hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Refrigerators
Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around $80.00@appliancefactoryparts.com. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Jul 30, 2009 | LG LRSC26940ST 36" Side-by-Side...
The fridge side by side door. Freezer & fridge stop working I can hear the motor trying to go but doesn't cool
When you say motor I assume compressor. No start compressors can be an electrical component like the start relay or the compressor itself. Eric
Jun 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
Refrigerators Logo
111 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
