Question about Samsung NC10-14GW Notebook
My Samsung p400 laptop won't power on. There are no lights on the front panel, even when the charger is in there. I had the multimeter onto the power supply and that is fine. Battery shows 80% charge with the level meter underneath. If I leave the battery out and power out overnight, and then plug power in alone, there is a green light that slowly dims to nothing.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power
adapter only. If the computer turns on, then the battery is defective & needs to be
replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the
power adapter using a voltmeter. Compare the voltmeter reading to the nominal value
written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re
-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try
swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
Jun 13, 2014 | Samsung N150 Netbook
I dropped my HP elitebook 6930p. it won't turn on. the blue on/off light blinks once every 5 seconds. what should i do?
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test HP EliteBook 6930p charger with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
Jan 01, 2013 | HP EliteBook 6930p Notebook PC
Mini dell 910, no power
Possible causes:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-dell-inspiron-mini-910-30w-ac-adapter-19v.html
Nov 21, 2012 | Computers & Internet
I m having samsung netbook x 11 model . charging pin is not working properly.how do i solved the problem, plz let me know
I'm assuming that you mean the charger is not charging the battery or powering the laptop?
You first of all need to check that the power adaptor is working ok, that it has a steady green light and not flashing, a flashing light would indicate power is failing to reach the motherboard.
You can test this using a multimeter set to 20 volts and probe the red end to the inner of the jack that goes into the laptop and the black to the outer
If the pin in the laptop is loose or sloppy, it will need replacing. You need to dismantle the laptop and remove the jack port, this is soldered onto the board example of the part here
Jul 27, 2011 | Samsung Computers & Internet
My Samsung p400 laptop won't power on. There are no lights on the front panel, even when the charger is in there. I had the multimeter onto the power supply and that is fine. Battery shows 80% charge with...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
6. The motherboard could be defective & needs to be replaced.
Sep 14, 2010 | Samsung NC10-14GW Notebook
Wont turn on at
This is common when the charger is not working anymore and the battery is almost dead. It has just a few seconds of life.
Verify that the charger is working. Plug it in and see if any of the light come one in the front then unplug. If not lights then it isn't charging. Even if the light comes on, you need a multimeter (12.00 at walmart) and put it in and check for the 24/28Vdc (read what the output is on the bottom of the power cord).
Oct 12, 2008 | BenQ Joybook 3000-01 Notebook
In Trouble can't power on my laptop with or without battery?????????
Sounds like the AC adapter cable has a break in it.
If you have a multimeter you can test it. I use a paperclip to get to the middle if my multimeter probes are too big for the hole.
If it's got good constant power then the jack on the machine where the AC adapter plugs in is probably loose or broken.
Sites like laptopjacks.com sells new jacks that you could get someone to solder onto your motherboard.
Jan 14, 2008 | Acer Aspire 3000 Notebook
No power when at switch on
Sounds like the power socket on the laptop may have broken loose from the board. Very common. If you have a multimeter, try and check the voltage ont the tines where the main battery receives it's charge, with the ac adapter connected to the laptop. That will tell a lot. Good luck
Jul 25, 2007 | Acer TravelMate 290 Notebook
Samsung NC10-14GW Notebook Logo
441 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
