Question about Philips Vacuums
I have a Philipshq7300 elec.shaver purchasedin july 2009. I cannot get in to charge, has the battery had it? How do I get a new battery & what is the cost.
  • Philips Master
  • 17,130 Answers
The batttery can always wear off specially if the charging is not done properly for the first time or if the product has been on shelf for a long period. You will need to remove the holding pad to get access into the unit where the battery is located.
Possible that water can seep into while being used in the bathroom.
repalce battery with rechargeable type, do initial charging and set.
Posted on Sep 14, 2010
It will not hold a charge. Been plugin for days at a time then it will run a minute then stop
Hello Karen, It sounds as though may have a bad battery or the charger is shutting down before the battery gets fully charged.
Nov 01, 2015 | Black & Decker CHV1210 Vacuum
We have the GE sensor microwave WES1358DN1WW. It was made in 5/2009 & bought in July of 2010 brand new. it worked perfect til last week. i put something in it & it started to make a loud...
It's really a pain to open them up but if your feeling up to it, it sounds like the magnatron has vibrated loose and probably disconnected a wire. Disassemble and take a pic if u need help. It's pretty straight forward once inside
Apr 02, 2017 | Vacuums
The batteries will not hold a charge very long before it stops working.
Sorry to read about your problem, I hope this helps you out.
defective batteries time for new ones
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Vacuums
How do you take apart the Braun 4700 series shaver. I need to replace the battery, so i need to access the inards. Thanks
In the back of the shaver are two screws, one on each side of the plug pins. You need a tiny flat-head screwdriver. Take these screws out and the entire outer shell of the shaver pulls out from just behind the head.. Now your next challenge is trying to find replacement batteries with the little tip on each end.
Dec 09, 2010 | Vacuums
My Braun tootbrush has never charges-i have a 240 & 11v shaver socket but nothing seems to happen when i plug it in?
When charging a device on some type of charging block you need to plug it into a regular 110 socket as the block has the correct modifications in it for the device that it charges. This 11volt shaver socket is for older shavers that dont charge up you just plug them in and use them.I hope this helps you ....good luck
Oct 13, 2010 | Vacuums
I am charging Remington Shaver FS360 for the first time I have put in charge for almost 12 hrs (the instruction is to charge it for 24 hrs at the first time) but still the charge led is not glwoing. I am...
Wait the full 24 hours then try using the shaver. If it functions normally, then I would say only the charger light is not working. If the shaver runs down before the end of the 2nd shave, then you may have a defective charger and/or shaver. In that case, take it back where you bought it for a replacement.
Jan 06, 2018 | Vacuums
4210 and 4230 won't charge-new batteries.
I've been having the same problem myself. The charger is apparently built into the roomba main board. From what I've read there are two MOSFETs U2 & U4 that can go out and require replacement to fix the problem. More info here
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=3909
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
Jan 14, 2008 | Vacuums
Vacuums Logo
35 people viewed this question
Top Philips Vacuums Experts
Jim Parker
Jim Parker
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
