Question about Samsung LA22A450 22 in. LCD TV
Does Samsung LA22A450C LXL model have TCon? there is no picture only sound coming from our LCD
SOURCE: No picture or sound. Red light comes on then goes off.
I had the same problem with my LTP227W and it is also about 4 years old. Took it in to be fixed and they found it was two capacitors in the power supply. Parts for this TV are not available anymore but they were able to repair the power supply. The TV works fine now. Hopefully I can get another four years out of this. Repair cost was $150.
Posted on Feb 15, 2008
  • 113 Answers
SOURCE: lns4692d no picture
No it is the little board underneath the metal container at the top middle of the panel..the very top.
-Josh
Posted on Mar 14, 2008
  • 191 Answers
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
for bn94-00963b go and change your backlight inverter
Posted on Oct 05, 2008
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Posted on Nov 19, 2008
ginko
  • 19396 Answers
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
I have No Picture on a Samsung Model UN60EH6003FXZA HH01 TV.
TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board. In some models TCON board is integrated to the panel, In such cases you have to replace the panel.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 07, 2017 | Samsung Televison & Video
I have a Samsung model La32d403e2...every time I switch on everything is normal...but after a few minutes picture starts changing colour and then double picture...how can I fix that?
The TCON board or the LCD panel is Faculty. Can confirm by replacing the TCON board .
Feb 03, 2017 | Samsung Televison & Video
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 06, 2016 | Samsung 40 Inch UA40F6400 Full HD 3D Smart...
Samsung hp-s5053 bottom half goes black intermittently. Picture is fine, bottom half goes black, then picture comes back. Is there a replacement part I can try before disposal?
The Tcon board or the LCD panel is faulty. Can confirm by replace the Tcon board .
Jul 02, 2016 | Samsung Televison & Video
Samsung LCD TV 22inc Model No LA22A450C1, no picture ( white screen) only sound....
This type of failure is related to a defective Tcon board. I would suggest if you are DIY to check for proper connections from the main board to the Tcon board, if all the connections are good.. check for proper voltage from the power supply to the Tcon board. If all the previous checks are good, check for an open fuse on Tcon board.
Let me know if you require further assistance.
Oct 03, 2015 | Samsung Televison & Video
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Mar 31, 2015 | Samsung LN40A550 LCD TV
Samsung Model #LN32C540F2D comes on but no picture. screen is white and has colorful lines on the side of the screen.
Is it possible to post a picture of the screen with the colorful lines? You are looking at either a tcon and an lvds cable or a bad display. May be able to narrow it down if I can see a pic.
Mar 21, 2014 | Samsung LN32C540F2D 32 LCD TV
I have a 52 inch samsung lcd and i have a 6 inch vertical green lineon the screen
Looks like a display problem inside and might need attention of a qualified service technician.
Jul 12, 2012 | Samsung Televison & Video
Samsung LE40R51B no picture but turns on
i have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Nov 20, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LA22A450 22 in. LCD TV Logo
100 people viewed this question
Jerry Greenberg
Jerry Greenberg
