Question about Lincoln Welding Tools
Bought a new 140HD online. Worked great first Lb of wire,now when I try to strike a arc it barley sparks.Trigger works fine,wire feeds at whatever speed it is set at,tried different outlets.changed the wire,using a flux core for mild steel.Even tried to strike directly to ground,no difference.checked all the terminal connections for loose,all seems tight.Any ideas on what might be wrong? Steve
  • 3,600 Answers
Most likely Your inner Shield has worn threw and shorted out ry changing the inner wire feeder liner by removing the nozzle and remove the tip and pull the inner liner out and replace it. If it still does not work Check fuse on side panel be sure it is unplugged.
Posted on Sep 14, 2010
Hello my name is Darrell I just recently bought a Lincoln 125 hd wire welder at home Depot unboxed and set up as per instructions wire feed is fine but will not strike an arc can you he
Good evening Darrell, check that all your connections are correct and tight,and that the polarity is proper.do you have the right amperage from your fuse box. Good luck Jeff
Aug 27, 2017 | Lincoln Welding Tools
I have a century 125 110 welder, the welding wire backs up to gun when stricking arc
Hi there, Sounds like your wire speed is to slow or not feeding at all.Your wire may be crossed or the spool may be to tight.I lay mine on the side so the wheel shavings fall away from the wheels. and I open the lid to see whats going on.One time I got the wire twisted and It wouldn't work right and it finely snapped in to.Take the label off and that can help to.Feed some wire out with out striking an arc and watch the spool and rollers.Make sure wire is in the proper grove.One last thing you want to feel the wire push your hand back when you weld.Depending on the use you may need a new liner.Thank you for choosing FixYa.............Darryel
Aug 08, 2011 | Century Welding Tools
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
No arc/ no burn
You need to inspect the ground.Where it connects to the machine, and at the end. I bet one of the connections or the wire itself is damaged.
Jul 20, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
1997 Breeze hesitation while cruising
sound like your wires might be chaffing through and arcing out on a ground somewhere!
Jun 04, 2008 | 1997 Plymouth Breeze
Welding Tools Logo
66 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
