Question about Minolta DiALTA Di181 Printer
Error c1440 - Minolta DiALTA Di181 Printer
  • 1,110 Answers
C1440 code means that your exposure lamp has failed or the circuit that powers it has failed. The exposure lamp is the light that comes on from under the glass and scans your original. Most likely failure is the exposure lamp itself. I would say between the 2 that 90% chance the failure is in the lamp. If you want to replace it yourself the part number you will need for the lamp is 1177-7801-01. If you can not locate one reply back to me here, as I have a parts machine I could find you a lamp.
Good Luck and Thank You for using Fixya.
Posted on Sep 14, 2010
Problem code c1440on 2003 ford explorer
C1440 Pressure Transducer Input Circuit Failure YES
C1440 (ABS only) Pressure Transducer Input Circuit Failure ABS Module Go To Pinpoint Test P .
Normal Operation The brake pressure switch provides an additional speed control deactivation if the brake pedal position (BPP) switch fails. When the brake pedal is pressed, 1700 kPa (246 psi) of brake fluid pressure in the brake master cylinder opens the brake pressure switch, removing B+ voltage to the speed control servo electric clutch.
    Possible Causes
  • circuit 10 (LG) open
  • circuit 307 (BK/YE) open, short to power
  • ABS module
  • brake pressure switch
  • speed control deactivator switch
PINPOINT TEST P: DTC C1440 (ABS ONLY) - PRESSURE TRANSDUCER SIGNAL FAULT CAUTION: Use the flex probe kit for all test connections to prevent damage to the wiring terminals. Do not use standard multimeter probes.
Test Step Result / Action to Take P1 VERIFY THE DTC
  • Connect the diagnostic tool.
  • Key in ON position.
  • Clear DTC C1440. Road test the vehicle. Repeat the self-test.
  • Does DTC C1440 repeat?
Yes
GO to P2 .
No
The system is OK at this time. P2 MONITOR THE BRAKE PRESSURE SWITCH PID FOR CLOSED POSITION
  • Enter the following diagnostic mode on the diagnostic tool: ABS Module PID.
  • Monitor the powertrain control module (PCM) brake pressure switch PID.
  • With foot off the brake pedal, does the PID read closed?
Yes
GO to P3 .
No
GO to P4 . P3 MONITOR THE BRAKE PRESSURE SWITCH PID FOR OPEN POSITION
  • Monitor the PCM brake pressure switch PID.
  • While pressing the brake pedal, does the PID read open?
Yes
GO to P9
No
GO to P7 . P4 CHECK THE CIRCUIT 10 (LG/RD) FOR AN OPEN
  • Key in OFF position.
  • Disconnect: Speed Control Deactivator Switch C1025.
  • Measure the voltage between the brake pressure switch C1025-2, circuit 10 (LG/RD), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to P5 .
No
REPAIR the circuit. CLEAR the DTCs and REPEAT the self-test. P5 CHECK THE BRAKE PRESSURE SWITCH
  • Measure the resistance across the brake pressure switch pins, component side.
  • Is the resistance less than 5 ohms?
Yes
GO to P6 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P6 CHECK CIRCUIT 307 (BK/YE) FOR AN OPEN
  • Connect: Speed Control Deactivator Switch C1025.
  • Disconnect: ABS Module C155.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE). harness side and ground.
Yes
GO to P9
No
REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test. P7 CHECK CIRCUIT 307 (BK/YE) FOR A SHORT TO POWER
  • Disconnect: Brake Pressure Switch C1025.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE), harness side and ground.
  • Is any voltage present?
Yes
No
GO to P8 . P8 CHECK BRAKE PRESSURE SWITCH
  • Start the engine.
  • Measure the resistance between the brake pressure switch C1025 pin 1, component side and the brake pressure switch C1025 pin 2, component side while firmly pressing the brake pedal.
  • Is the resistance greater than 10,000 ohms?
Yes
GO to P9 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P9 CHECK FOR CORRECT ABS MODULE OPERATION
  • Disconnect all ABS connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all ABS connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. TEST the system for normal operation.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
Jul 01, 2017 | Ford Cars & Trucks
Bought tool 60794 and need problem code c1440 explained to me for 2003 ford explorer
Just follow the diagnostic flow chart in the shop manual. Way too much to ask us to type it all out for you.
Minolta Di 181 c1440 call service
Exposure lamp is out. This will be the very bright light under the glass that should come on when you put a document on the glass and press start. put a document on the glass and leave the document feeder up press start no bright light burned out try reset. To reset must remove back cover and press a tiny black switch on the main board. Power must be on. Lower right hand corner Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Try that if you need a lamp
Sep 16, 2015 | Minolta Office Equipment & Supplies
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Code Meaning c1440
WHAT IS THE VEHICLE??
Jun 24, 2013 | Cars & Trucks
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
ABS light staying on, lost my cruise control, overdrive shut off going down the highway a couple of times, and not shifting right when going 55-60 on the highway when shifting into 5th gear i.m guessing....
its the solonoids on the solonoid block, 3 of them are sticking, there is alot of videos on what to do,on you tube, very common problem, mine runs and shifts great now
Aug 09, 2017 | 2003 Ford Explorer
Minolta dialta di 181 error no c1440 machine not working
Scanner exposure lamp out. Try opening thr front door to reset, if not new lamp
May 07, 2009 | Konica Minolta DiALTA Di183F Copier
113 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
