Question about Durabrand STS92 System
Speaker wires too short
I have a sts96 but the rear speaker wires are to short..Can i splice them and add more wire?
  • Anonymous Jan 09, 2009
    I have the same problem, the back wires are too short, but my surround sound system is the Durabrand Model HT-3917. Is there a way to add more wire to this system?
  • home3917 Jan 09, 2009
    I have the same problem, the back wires are too short, but my surround sound system is the Durabrand Model HT-3917. Is there a way to add more wire to this system? And do you know where I can get the wire if it is possible to do?
    Problem Solver:
  • 16 Answers
The rear speaker wires can be extended but for each extra foot of wire, there is an increase in resistance, therefore, the rear speakers will not be as loud as intended. The increase in wire size will not solve the issue since you are splicing into the already existing wire. You may end up with a weaker surround sound so just compensate with the surround volume.
Posted on Apr 16, 2009
  • 57 Answers
Ya you can but you should be very carefull while you are extending the wire because the wire of the spreaker will have very thin copper wires if you are not carefull it will be damaged so be carefull will extending wire
Posted on May 25, 2008
The spring loaded wiring ports will not retract
The question is not clear and so I request for the full observation. The wiring must be removed and fully tested for any short in the rear speakers, check the resistance of the speaker before it can be connected.
Oct 27, 2011 | Bose Lifestyle 12 System
How can I make the speaker wire longer???
To extend speaker wire you need to splice it. The proper way to do this is with bu tt connectors. You will also need a crimper, but a cheap set from the hardware store will do the job just fine. Make sure all components are off and unplugged when doing this. It is also a good idea to splice 1 conductor at a time so that you don't accidently cross the wires and end up shorting your system. Once your wires are spliced through, it is also a good idea to re-insulate your connections with electrical tape.
Jan 04, 2011 | RCA RTD317 Theater System
I have a Phillips HTS HTIB and would like to know if I can add to the speaker wire length by splicing?
Any splicing to a cable will degrade the signal quality and will compromise the integrity of the cable itself.
As a repair maybe for a short-term fix, but I wouldn't recommend cutting up a good system.
Nov 18, 2010 | Philips HTS-3555 System
I have a RCA RTD315W hone theater system, it's been working great except he speaker wires are too short. I have to place them on tv trays when I use the system. I would like to mount the speakers on my...
You cast your Mark I Eyeball on the speaker wires then buy something like it at Home Depot. Lamp cord will probably suffice and it's cheap. Buy a spool of it. Then you TURN THE UNIT OFF and carefully splice in the desired length of wire (*), one conductor at a time so you don't criss-cross anything. Make sure you leave NO conductors exposed in the joints.
* They make a number of solderless splicing devices. Ask the guys at HD when you buy the wire.
Feb 08, 2010 | RCA RTD300 System
Lengthen speaker cable
i had same problem. yeah, there's not much wire included. i just purchased a spool of speaker wire and got the length i needed. since the wires are usually color-coded, i tagged each new wire with 2 stick-on-spots, with sticky side back to back over the wire, and wrote RR & LR to make it easier for locating them in a jumble. you can also just splice and tape extra wire on but i feel every cut cuts back on quality of sound.
May 27, 2009 | Montgomery Ward Audiovox DV1201 Theater...
Lifestyle 30. sound stops, i unplug and plug back in and works for short time and quits. unpllug and plug back and works a short time and quits.
What you describe, sounds like a speaker short. Are you using the Bose wiring with their ends and no cuts in the wire? (splices) It's not too uncommon to extend or shorten a wire. The fastest way to find a short is to disconnect your speakers at the speaker. Be careful to keep the wires separate if they are not on plugs and turn on. If it cuts off (power) or says (protection) on the display that lets you know your speakers are ok and you have a short in the system or a wire. Next, disconnect wires at the sub one by one and test until it causes the system to cut off or short. Leave that speaker disconnected from the sub and test with all others connected. Now you've located the channel that has the problem. First just connect the wire again to the sub. if it cuts out, run a new wire from the sub to the spkr, for testing purposes make it a short wire if possible and test. If you need to use a Bose plug at the sub to test spkrs go buy one at Bose, don't cut your factory wire just yet. If a new plug works then cut and replace. Make sure you use electrical tape not scotch tape or duct tape. If it works fine, test the new plug on the old wire and see if it works. If it does your done, if it doesn't, run a new wire to the speaker with the new plug on it. If after all this and it still doesn't work. Sounds confusing I know, It's just process of elimination, that's how we do it in the field. If all your speakers are disconnected and it still cuts out, it could be the sub or the receiver. Take it to a Bose store and they can check each piece for functionality. If it needs repaired let Bose do it. Hope this helps.
May 10, 2009 | Bose Lifestyle 28 System
Do they sell extentions for the speaker wires for the HTS-3565d?
you best bet for that much wire needed would be to go out to eather wal-mart or radio shack and get a spool of speaker wire normaly the mid range wire is a good bet for home use
Mar 27, 2009 | Philips HTS-3565 Theater System
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
Add speakers
Use the KEFF wireless rear system as this is the only system that works without breaking up ,costs 400 quid but is worth it.
Hope this helps.
CABLE GUY.
Jan 03, 2009 | Panasonic Home Theater System System
Durabrand STS92 System Logo
302 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Rod
Rod
Geoff
Brian Sullivan
Brian Sullivan
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
