Question about Bosch Dishwashers
My 8 month old Bosch Ecosense soap dispenser has been sticking, so the whole cycle will run with no soap being used. I see a spring near the sliding dispenser door, which I cleaned with vinegar, but that dodnt seem to help. Seems to open and shut fine when I go to put the soap in, just not during cycle. Any ideas?
COXY
  • 76 Answers
SOURCE: Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Posted on Nov 18, 2007
  • 3 Answers
SOURCE: Dishwasher soap dispenser sticks
Mine dishwasher (a Maytag) did this also. At first it was becoming stuck because of the soap. My repair guy cleaned it and I switched to liquid soap and it worked great another 2 years then did it again. That time it was just wore out and had to be replaced. I was told it was no longer available but we found it here http://www.repairclinic.com/and our repair guy installed it. He was amazed because he had even called everywhere.
Posted on Jan 02, 2008
catriver
  • 878 Answers
SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Posted on Jan 16, 2008
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
Soap dispenser does not open every time
the spring that tensions the lid is broken or otherwise not working. I would look at the hinge side of the dispenser and see if spring is still intact. When you release the lid, it should snap open without much difficulty so if it doesn't do that, then I would suspect the spring.
May 12, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch #SHU9955 Integra dishwasher for the last three uses, the soap dispenser door was open with the powder soap caked in the lowest one half of the pocket dispenser. The dispenser door locked and unlocked...
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Oct 09, 2008 | Bosch Dishwashers
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machine (bosch)
It's caused by blockages the holes in the water divertor (or whatever it's called) in the roof of the soap dispenser. Not enough water flows through during the cycle to cause the siphoning action to happen which then flushes the softener through. I've noticed these holes regularly get blocked with mildew (black staining) since water lays on the plastic providing an ideal environment for mildew . A quick solution is to clear the holes using an old toothbrush or similar. Longer term is to carefully remove the water diverter panel by pulling down at the back and also sliding a thin metal blade (eg old knife) between sides of the panel to unclip it as you pull down. Rather fiddly and danger of splitting the plastic. However if you succeed you can then clean all the mildew away and replace. However it will return unless you manage to keep the soap dispenser dry - perhaps by leaving drawer open. I suspect this is a design problem since it never happened with an old Hotpoint machine I had.
Nov 11, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Dishwashers Logo
262 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
