Audio on home PC not working...
I have never had a problem in the past and just a week or so ago, my sound quit working. I went to troubleshoot and it says that there are no audio devices/speakers installed. I bought new speakers...did not work. I tracked down the name of my driver Realtek AC '97, I went to website and reinstalled...worked for about 30 min and quit again! HELP!?!?
  • rajachowdary Jan 02, 2009
    i had a new os and i rebooted my pc somanytimes and my pc audio is not working
I dont has audio in my desktop. Please can you help my.
Posted on May 16, 2009
Three weeks ago my refrigerator went out including the freezer. We pulled it out, used our wet/vac and cleaned it out then turned the reset button and it worked fine. A week later it went out again and we...
im not sure what reset button you are using / but cleaning it out was good . and if it started running that was good. when it quit the third time . things that would cause this could be the cold control / very common / and at 15 yr old i would replace the compressor relay . that starts it . sometime you can hear it clicking or humming . ( trying to start . . so try the relay .. . and ck for bad connections on old wires to the compressor as the get brittle and burn off .. mm hope this helps .. feed back .. pls
Jan 19, 2011 | Amana Refrigerators
The left one quit working about 6 weeks ago today
Hello! a device called the Tail Light Relay; Located in the under dash fuse/relay box is the likely culprit...It controls the left/right brake lights but not the middle brake light...Also check that the L/R brake lights have a solid ground...Use an ohm meter...Zero ohms to negative battery terminal...
Guru........saailer
Apr 30, 2010 | Pyle Pl1157rd Led Brake Lights Light Bulbs...
Aspire 5630 laptop sound does not work.
hi sir
go to the ]
start>
control panel>
soung and devices>
voice>
test hardware>
it work's dont forget to fix..
Sep 02, 2008 | Acer Aspire 5630 Notebook
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
No sound
Did you have storms go through your area and lightning strikes or power surges? We did a few weeks ago and I have very raspy sound but perfect picture...
Mar 04, 2008 | Sony DAV-S300 System
Creative 5.1 Soundblaster Live problems
Hi Arrion
had the ame problem two weeks ago. computer progressively getting slower then no sound. I have reloaded operating system which got rid of the virus ( if that was the problem)and now it all runs as fast as before and the sound came back to life. hope this helps
Nov 24, 2007 | Creative Labs Sound Blaster 5.1 Audio...
Center channel quit woring
The center channel amplifier in the main unit isn't working. Check the warranty. If it's still in force Yamaha will fix it free. If out of warranty, they'll give you an estimate.
May 15, 2017 | Yamaha Audio Players & Recorders
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
