Question about RCA Televison & Video
RCA hd50lpw62a green power light comes on blinks and goes off tv never comes on.
  • RCA Master
  • 8,617 Answers
That set is famous for faulty flybacks. But its an easy inexspensive fix that takes under 30 mintues to do. You can get a new flyback at the following link for around 50 dollars and they provide free online tech support so you can do the repair yourself. You would need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Posted on May 15, 2008
Have you taken out your bulb and checked it? That is what happened to mine, Pwr light would come on and then turn off. My bulb was burned out.
Posted on Sep 22, 2008
Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | RCA D52W19 52" Rear Projection Television
I have a rca hd50lpw62a and its slow to turn on and dim when on.
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.Your part # for the lamp is 265866 and you can find it here: http://www.discount-merchant.com/RCA-265866-265919-269343-271326-270414-Lamp-p/rca-lamp-265866-26591-269343-r.htm Good luck and blessing for your house!
Feb 10, 2010 | Televison & Video
RCA R56WH78 Green LED Blinking
Ck 3 capacitors on deflection board cp150 2200uf 16v use 25v if it is puffed up on top it is Bad other 2 are 220uf 35v cp114 cp120 resolder all pinns on FBT flyback transfomer.
Nov 12, 2009 | RCA R56WH76 Projection Television
I have an RCA HD50LPW62A television set....We recently had a power outage. The green power button is on and will not go off. We have tried disconnecting the TV and plugging it back in again, to no avail....
usually has a bunch of bad capacitors in the power supply. they may have the top puffed up. these are in the power supply where there are high voltages. not an easy repair
Feb 24, 2009 | RCA HD52W59 HDTV Projection Television
My Rca hd50lpw62A turns on and sounds comes on but only the light blinks and a loud whirring sound begins...
GET rid of that TV it's a piece of JUNK! I had A 50 inch dlp color wheel went than the lamp the the digital circut board went and they want $600 for a new board . Not worth fixing(if by some miracle you can find any parts) sell the parts and move far away from anything with RCA on it. My new pioneer 5010 plasma is AWESOME!! $2600 tiget direct.
Aug 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
904 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
