Question about Panasonic Televison & Video
The model of our Panasonic TV is TH-21Z3 with board No. TNP-190227 Another No. stamped on its board is MD-6113 GZ. Its primary I.C.'s are Jungle - AN5163 System - MN152811T2E Regulator - STR30115 Vertical - LA7835 My technician needs an schematic diagram for this model to determine what causes the busting of parts that caused the vertical problem. Only a single line appears on the screen and won't open. Could you lend us help please!
  • Panasonic Master
  • 12,061 Answers
Http://www.scribd.com/doc/3545737/Panasonic-TH42PX75U-Chassis-GP10DHU-TV-Plasma-Service-Manual
Above is a service and repair manual this has everything he should need print it out and i am sure he will be thankful. Either that or send him the link...
Posted on Sep 14, 2010
I need a diagram for TNP A5808 PSU panasonic.. can anyone help me pls...thanks...
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 18, 2016 | Panasonic Viera TX-L32B6B 81.3 cm 32"...
Are the tnph0716abs and the tnph0716ads A boards compatible?
no they two boards are slightly fifferent and will not interchange with each other. You should be able to get the proper board for your model from www.tvrepairworld.com
May 16, 2012 | Panasonic Televison & Video
Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Aug 01, 2011 | Panasonic Televison & Video
NO POWER FOR A PANASONIC VIERA TH-50PZ800A
I would suggest you try different power points in your house to eliminate whether the cause of the problem is based on your TV.
If it is the TV check the cable for any damage. you can view more detailed information at http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/Operating-Instructions/model.TH-50PZ800U.O#ts
There is also a guide for the warranty of the unit.
May 23, 2011 | Panasonic TH-50PZ800U 50 in. HDTV Plasma...
My panasonic tv (model TH-50PH10UK) won't turn on, the power light only shows red blinking.
The tv power supply board have problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 23, 2011 | Panasonic TH-50PH10UK Television
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
Jan 28, 2010 | Panasonic TH-42PX60U Television
TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Jan 19, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
May 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Model #Th-42PA25
it is just an example for the part that should be replaced that is why i suggested that a service technician should check the tv physically to determine the part that needs to be replaced.
Sep 05, 2008 | Televison & Video
Televison & Video Logo
447 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
