Question about Durabrand Portable DVD
Power and battery
Not only is the battery not charging but none of the power cords work,no power lights of any kind,had the master checked out,nothing was worng with it,so tell me how come I have no power at all???
  • 3 more comments
  • Anonymous May 15, 2008
    i am having the same problem what should i do?
  • franklinsgt May 16, 2008
    Hello i need a new power cord for portable dvd player DUR-7 S/N RN160ED023585 DC IN 9V =1.5A Thanks
  • lboogie27 Jun 02, 2008
    I am having the same problem. When I plug it in the power will not come on and neither will the power lights.
  • Anonymous Jun 02, 2008
    I have the same problem. Absolutely no power at all. This was purchased for my son as a christmas gift in December 2007. Worked fine for a while and now does not work at all.
  • Anonymous Jul 14, 2008
    my problem is similar, No lights on the dvd portion. I can still use the power cord for the slave unit which works fine. any suggestions?
    i'm thinking maybe a bad battery pack?
  • 68 Answers
You problay have a bad power cord you can buy a power cord at a place like target or walmart maby even radio shack
Posted on Jun 24, 2008
Samsung 145
Dear frnd,
Probably its battery problem but before change the battery you have confirm first its battery or Adopter problem. you need do first check the adopter to another laptop which has same charging pin . if its doesn't work with another laptop then you change the adopter but if the charger works with other laptop then you need to change your battery. try it..
Jan 15, 2014 | Samsung N145-JP01US Netbook
When you power on a system, and refuse to power what is the solution?
Try another outlet, Try another cord. You get Nothing? No lights, battery Charge light? Fan? Has the laptop's AC jack been damaged, pulled by the cord? What kind of laptop, Make, Model, OS you are using?
Dec 18, 2012 | Computers & Internet
THE SWITCH ON IS NOT WORKING CAN YOU HELP ME TO FIX IT
The Switch ON? Are you talking about the Power Button? If so it could be that your Power Cord is bad. Some models of the Power Cord has a light on it and some laptops light up somewhere when the power cord is plugged in and working.
You might have been working off your battery and if the power cord is bad it was not charging the battery and now nothing will work because the battery is completely drained.
If the power cord is good, you might have a Static Charge Buildup. Remove the power cord and the battery, then press and hold the power button for 30 seconds. After 30 seconds put the power cord back in (not the battery, leave it out) and press the power button. If it starts booting you had a Static Charge Buildup and can put the battery back in now.
If all fails, take an ink pen and stick it inside where the power cord goes. If it is not tight then the DC Power Jack is bad and need to be repaired. This will require a complete disassembly of your laptop.
Mar 23, 2012 | Samsung N150 Netbook
My samsung N150 power switch is not working
Mar 23, 2012 | Samsung N150 (36725723009) Netbook
Why wont my lap top come on
Hello there.
There's a chance that it's a problem with the battery. But we do need to run some tests to determine the cause of the problem.
1. Kindly make sure the wall outlet is working by plugging inanother device like a TV or lamp, just to check if power is coming through it just fine. 2. Turn off the laptop completely. Unplug all the cables connected to the laptop, including the power cord then remove the battery. 3. Plug the power cord back to the outlet(without the battery inserted) then press and hold the power button on the laptop for 10 seconds. Then check if it would turn on. If it does then it means the problem is with the battery and it needs to be replaced or you can try to charge the battery again with the laptop turned off.
It would also help if you can give me the complete brand/model of the laptop.
Have a nice day.
Nov 21, 2011 | Toshiba Computers & Internet
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
Laptop will not charge. Brought new battery and and it did charge for a while now it will not charge at all. Changed power cords and still nothing. Need all programs for classes. It's urgent that...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 21, 2010 | Compaq Computers & Internet
Let the battery power down, plugged back in and now computer will not come on at all, took battery out, nothing, not even the little battery flash light, even tho power cord in and blue light around cord
Need to check the power cord to see if it is running at 19.5 fisrt. The power cord may be your whole problemand it cheaper than the other problem I see.
If power cord is ok take battery to the battery store to check it's cells. it sounds like to battery is bad. but the power cord should still bring the unit up. If the battery is ok and the power cord checks out the charging unit is bad and is costly.
Dec 07, 2009 | HP Pavilion dv9000z Notebook
Please,phone won't turn On
Take of the battery and let the phone stand for about 20 min without the charger or battery connected. Afterwards connect the charger only without the battery and see if the phone comes on. If nothing happens, attach the battery and disconnect the power cord to see if it powers up. If that does not work, keep the battery attached, then connect the power cord and see if it powers up. If none of these work, you will have to contact your manufacturer or wireless provider.
Nov 29, 2009 | Nokia 6210 Navigator Cell Phone
Battery pack charge
From your description, it sounds like a bad battery pack. You may find it hard to locate one, maybe check on Ebay every once in a while, or take the pack apart and see what kind of cells are in it.
Probably not what you wanted to hear, but replacing the pack will probably fix it.
Hope that helps...
Geno
Mar 24, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Durabrand Portable DVD Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
