Question about Lexmark Z2320 InkJet Printer
Printer wont print after replacing the cartridges
    President:
  • 2,571 Answers
Take them back out, make sure the chips are clean, make sure you remove the tabs (tape strip) and refit
Posted on Sep 14, 2010
  • 48 Answers
SOURCE: printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Posted on Jun 18, 2008
  • 21 Answers
SOURCE: printer
Most likely your print head is clogged, there are 2,000 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try reseating the ink cartridges(take them out turn off power, unplug printer, power back on & wait for it to get done making noise) then proceed doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads
Posted on Sep 03, 2008
badperiyac
  • 52 Answers
SOURCE: replaced cartridges now printer wont pring
is the cartige no. is same as privious
Posted on Sep 08, 2009
pineworks
  • 4041 Answers
SOURCE: printer wont print ink keeps blinking on system
Hi
You not say what make of printer you got so not can gave you much help, because there is a reset code for different printers, the flashing lights you may be getting it because your, waste ink pads need changing and after this you need the reset codes for it but some times just the reset code will do the trick for it to print again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
  • 232 Answers
Turn the printer on. Remove the cartridges. Gently clean the electric contacts on the cartridges and the cartridge carrier. Put the cartridges back in. If the light is still flashing, and your printer won't print, one of your cartridges is faulty. I suggest you go to the refill shop and consult them which cartridges needs a replacement.
Does any message appears on your monitor when you try to print something? Usually, a message saying "problem with black/color cartridge" or something similar, that's why I am asking.
Posted on Apr 15, 2010
My print cartridge light wont go off and it wont print nothing what should i do
I think ur printer cartridge ink is finished. Other wise the cartridge circuit is dear.Pls replace ur ink cartridge .inform me result
Jun 14, 2011 | HP PSC 1410 All-In-One InkJet Printer
Epson bx300f printer wont print black.I have replaced all ink and run maintenance checks
According to your problem first make sure the cartridge you have replaced are original and not refilled old cartridge. Always using original cartridge is recommended. If the all of the above conditions are OK then first align the cartridges and also clean the cartridge head. You can also replace the same cartridge after a little shaking of cartridge. Take out the cartridge from the printer by the recommended process, shake the cartridge and make sure the ink is OK and not dry, then replace it again. open the printing preferences window form printer properties in your PC and align the cartridges, then reboot the printer after deleting all print job in print queue.
Apr 28, 2011 | Office Equipment & Supplies
My printer wont print. The ink cart went out and then was replaced but the orange light continues to flash and wont print
replace the cartridge with a new one probably the cartridge is not good or malfunctioning!If problem persists disconnect the printer from power outlet wait for 10 seconds and connect again
Jan 20, 2010 | HP DeskJet 940c InkJet Printer
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Printer wont print
Dec 22, 2009 | HP DeskJet 930c InkJet Printer
Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
Remove ink cartridges,then print head.
Clean print head with dry cue tips.
Apply strong suction over black print
jets on print head.
Replace print head and cartridges.
It worked for me.
Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Printer wont work
CARTRIDGE OUT OVERRIDE
From the main menu on the printer, press "right arrow" to "System Setup", then press "Select" (green button with check mark)
Press "right arrow" to "Print Quality" and press "Select"
Press "right arrow" to "Replace Supplies" and press "Select"
Press "right arrow" to "Override Out" and press "Select"
Press "Select"
If "stop at out" is selected, the printer will stop printing when a cartridge reaches the recommended replacement point. If "Override Out" is selected, the printer will continue printing when a cartridge reaches the recommended replacement point. The factory default settig is "Stop at out".
Apr 30, 2009 | Office Equipment & Supplies
My lexmark color jet z23 wont print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Aug 14, 2008 | Lexmark Color JetPrinter Z23 InkJet
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Lexmark Z2320 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
