Question about Kirby G5 Bagged Upright Vacuum
Hi there--My G5 had a burning smell and when I took it in to be looked at I was quoted R1800-00 as I was told it needs a service and then certain repairs.I am dissapointed as this is very expensive and I thought maybe I could get a quote elsewhere.Please help!I live in JHB Thank you Judy
  • Kirby Master
  • 17,129 Answers
Hi Judy, Youmust have asked what was the burnt component. If this was the motor then there is no chance of a cheape service but if this was a the surge capacitor then it is just a easy job to replace.
So Whenever there is an inspection please ask for the correct technical fault, the details of repair( if replaced or repaired) warranty on work .
Taking it to several place may finally end up tampering the machine. So the known person can be believed in to prove himself.
Posted on Sep 14, 2010
Riccar RSL4 Supra Lite Very Noise/Slight Burning Smell
I am looking for a new motor for my 8920 Ricaar Vacuum. Can you lead me in the right direction. I can put it in my self. I replace them before. I used Ricaar for 25 years. Love them
Jan 02, 2014 | Riccar Vacuums
My dyson DC14 was at first having that something caught sound. I took off the bottom, cleaned hair out especially around the belt and it stopped with the sound but now there is a burning rubber smell. I...
Sorry to hear you're having difficulties with your DC14. It's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting over the phone with you. Once they've identified what the issue is, they'll be able to recommend the best course of action, and arrange service for the cleaner if necessary. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 09, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I bought this second hand, so have no manual for parts, etc. I smelled something really bad, am assuming it was the belt. How do i release the head of the vaccume to get to the roller. It needs cleaned...
rotate the front belt lifter from green to red then rotate the locking knob above the nozzle. and the head will lift off. it helps if you put the height adjustment in the highest setting. did it smell like rubber burning?
Jan 01, 2010 | Kirby G5 Bagged Upright Vacuum
G5 motor is on it's way out
If you are the original owner,you can send it to Kirby rebuild and have them rebuild it.For a non-original,it is around $300.They go thru it,replace the parts needing replaced,buff the metal covers to remove the blemishes,and send it back to you.It will look and operate as it did when you first purchased it.Call Kirby Rebuild in Cleveland,Ohio.
Oct 26, 2008 | Kirby G5 Bagged Upright Vacuum
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Burning smell
Hi. What does the burning smell of? Is it 'rubbery', or is it acrid and 'chemically'?! The most common item to 'burn' is the belt which drives the rotating brush at the front. Does your cleaner have a belt? This would give a burning rubber smell. The instructions should explain how to change the belt - have a close look and see if the belt has been slipping on the motor spindle. If it has, then it'll probably be worn at this point and should be replaced. A common cause of this happening is the brush bar getting caught in something - edge or rug, etc - and being forced to a standstill. If the smell is more 'acrid', it could be a problem with the motor. This is a repair service job.
Sep 22, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
42 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
