We live in an apartment complex and have a Trane Air Conditioner, each unit has its own central air. I believe the one in our unit has clogged drain pipes, when we first moved in we didnt change the air filters and when we did, the filter was extremely dusty. My wife uses alot of powder and when I clean the drip pan below the grill where the drips into, I found a thick layer of whitish doh like crud.I feel like it is clogging the the 2 whites pipes that go from the drip pan into the drain down below on the floor. The air conditioner/heater has a hot water heater below it in the closetwith its own black plastic drip pan with a small white drain pipe going to the floor. The a/c drip pan overfills and the water spills out everywhere. I am unsure exactly how to unclog the 2 A/C pipes because of tight spacing. I tried using a wet dry vac unsuccessfully. I have other ideas but really would like expert advice.
  • 455 Answers
Hello You have to cut the pipe and blow out each end,You can use a 1"rubber hose from an auto parts store & 2 hose clamps, If you can't find the end.This will allow access in the future to clean out the pipes.It will slip over 3/4" PVC pipe.They sell a PVC pipe cutter but a hacksaw blade works well.Get ready for all the water in the pan once you cut!
Posted on Sep 14, 2010
BTU of air conditioner?
Here are all the specs of the air conditioner whirlpool ACU102PK
Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
Hope this helps you and Good Luck.
May 13, 2010 | Whirlpool ACU102PK Air Conditioner
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Tempstar central air conditioner The AC unit is not comin on How can you tell if the unit is bad
check to see if you have a safety cut off switch installed on your inside unit's drain line. if so, pull it out or unscrew it they are easy to access the little float switch that will cut your unit off if the drain line is clogged.
most of the time this is the cause of a unit not doing anything at all.
if this does not work the next step, if nothing is happening at all, is to open the inside unit and check for control voltage (24v).
Oct 08, 2009 | Ruud Central System Air Conditioner
Where is the capacitor located in a trane central air unit?
the cap and all other electrical components are safely placed inside the unit's box. You have to take the side off of the unit and the metal box is on top please throw the disconnect of and remember there is still 24 volt live inside. The 24 volts is coming from the furnance.
Aug 13, 2009 | Ruud Central System Air Conditioner
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
I have a central air conditioning unit in the apartment where I live. It is a split unit - somewhere outside is my outdoor unit (and everybody elses too). Anyway I seem to get way too much humidity in my...
the humidity problem is from the condesation drain. It is more than likely to be clogged up keeping water in the condensation pan causing the humidity problem. This can be cured by a wet vac put onto the outside drain for the inside condensation pan and turned on. this removes the algae that builds up in the a/c condensation pans. Also, an a/c unit is designed to last 25 to 30 years depending on the location of the outside unit. Inside unit being an apartment, has other issues, it just may need to have some preventive maintenance done such as coil cleaned filter changed, motor oiled, etc....
Jul 08, 2009 | Carrier 38CKC030 Air Conditioner
Apartment Central A/C Unit Not Working Properly
Sounds to me you are low on freon and the evap coil in icing up
Jun 25, 2009 | White Rodgers 0754-1 Electric Water Heater...
The unit is leaking a lot of water from the bottom. What should I do? I do not see a drip pan and am not using the dehumidifier. It is vented to the outside but vent is raised up and not even with the...
All air conditioning units remove moister from the air.Which is good,it helps the moister on your skin evaporate faster,and helps cool you down.If its a central heat/cooling unit it should have some form of drain pipe to carry this moister away from the unit.Usually a white pvc tubing. Sometimes these become clogged with dirt,or even believe it not algae.If there is no drain someone didn't do the job right.(clean the gunk out of the pipe,or replace the tubing). If your talking about a window unit the unit will drain out the back of the unit,but the air conditioner has to be tilted in such a way that any water inside the unit will flow toward the back of the unit. (simply lower the outside end of the unit a little lower than the side stuck in the window).I see you mentioned a vent so you are probably talking about a air handling unit in your home.The vent should just be for fresh air.If you have a very tight house an air handling unit will be designed to bring fresh air into the house(to keep your air fresh).That is usually its only function.There should also be a small drain pipe leaving the unit somewhere.Some modern units even have a back up drain if the first clogs,and maybe even a signal that tells you the first pipe is clogged.
Jun 24, 2009 | Continental CEPAC1062-1 Portable 9800 BTU...
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
