Question about Philips 42PF9630A 42 in. Plasma Television
LIGHT BLINKS GREEN ....WHEN I PLUG IT IN ....THEN LIGHTS ON THE SIDE OF TV COMES ON...THEN GO RED LIGHT COME ON AND TV GOS OFF!!!!
  • Philips Master
  • 12,061 Answers
Www.tv.quuq.org/forum/index.php?action=dlattach;topic=701.
Above is your service manual, below is your user manual.
http://www.retrevo.com/support/Philips-42PF9630A-TVs-manual/id/278bh337/t/2/
Ok well I have seen this thing countless times, this is a fairly classic switchmode power supply, problem, insomuch, as the PSU, has sensed a major fault condition, and is attempting to shut down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, so the protection Circuitry, has "Sensed" this and done so. Sometimes, when it shuts down, the fault disappears temporarily, usually because the component cools down, then the PSU, will start again, sense the fault shut down, and over and over again, until it ultimately fails completely.This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office"Philips in your case here. Contact them and ask for a referral to a service center. Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
However if you wish to try DIY, (Not really recommended, if only due to the equipment needed to do so)Anyway, I have included the service manual for you to use. Work through the troubleshooting procedures, and try to isolate the issue with a view to repair.
Posted on Sep 14, 2010
Rca tv L46WD22 and green light followed by 5 red flashing lights
These blinks (Flashes) are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check these link s
http://electro-medical.blogspot.com/
Dec 13, 2013 | RCA L46WD22 Television
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
TV not working
Check the lamp door assembly, if the lights are alternating red then green, then this might mean that the metal pin that looks like a roofing nail is not making contact with the metal clip. Remove screws, reset panel in place and turn on, the red power button should be the only light on.
Good Luck!!!
Aug 07, 2008 | Akai PT46DL10 46" HDTV-Ready Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
