How to install eclips in windows system. is true whithou Java eclips not install ?
  • 61 Answers
First of all, you don't have to install Eclipse. Download the required version of Eclipse from www.eclipse.org/downloads/ and unzip it, & double click the eclipse.exe to open it. Thats it. If you need to work with JAVA, its advisable that u install the latest version of JAVA & then use eclipse. Hope this helps!!!
Posted on Sep 14, 2010
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    Tip
    Installing the Java Development Kit for Windows
    Hi guys,
    Watch this video on Install Java Development Kit for Windows
    on Jan 26, 2011 | Sun Java Desktop System
    I have window me 200 but can i do to see videos in you tube the brosser dont' letme see
    To play videos on YouTube on Windows 2000, you should have java platform installed on your system. If you don't have java loaded in your system you can install it fromhttp://www.java.com/en/download/chrome.jsp?locale=en&host=www.java.com
    once you install java platform you should be able to watch videos on YouTube.
    Feb 05, 2011 | YouTube Videos
    How to instal java
    java is a program that gives you the feature to support java compatible software.
    1: go to this website java
    2: select you OS ( you can downlaod online or off-line java setup file)
    3: download java
    4: install in your PC
    Jan 12, 2011 | Computers & Internet
    I can't add arabic language to my computer
    How to Install Java in Windows XPProfessional
    Java is one of many third-party applications that enhance your experience onyour Microsoft Windows XP Professional operating system. Java, developed by SunMicrosystems, is a programming language and computerplatform that is the backbone behind many of the programs you use today,including games,businessapplications and utilities. Software developers choose the Java platformbecause it has been tried and proven to work the best. Java publishers focus onperformance, stability and security. It's easy to get the latest version ofJava and install it on your XP Professional system.
    1. Manually download. Visit the Java site to download the Java application;ensure the version is Windows XP compatible. If you have a 64-bit Windowsoperating system, pay special attention to the download; most Windows usershave 32-bit by default. Save the file to a location that can easily berecalled. 2. Begin installation. Close anyopen Web browsers and applications. Click on the saved Java download file.Click "Run." Read any warnings and agreements. Acknowledgeconfirmations as you proceed, selecting "Next" until eventuallygetting to the "Install" button, and click that as well. 3. Read intermediateinstallation messages. As the main Java application installs, you may encounteradditional advertisements. Read, make decisions, and click the "Next"button to proceed. A "Progress" window will indicate "Status:Installing Java." 4. Verify installation. Afterinstallation is complete, the Java setup window will show "You havesuccessfully installed Java." Click the "Close" button and resumeusing your PC per usual.
    5. For additional verification that Java was installed, refer back to theoriginal page from where the application was downloaded. Find the link"Verify Now." Click it to advance the page, and select the red"Verify Java version" button. Wait while the Web page verifies theversion.
    TIPS and WARNINGS
    After first-time Java installation, the application can be accessed from theWindows XP Professional "Control Panel" on the "StartMenu." After opening the app, click on the "Update" tab toretrieve the most recent version of Java.
    It is important to keep Java on Windows XP Professional systems updated forsecurity reasons as vulnerabilities might exist in outdated versions.
    Read more: How to Install Java in Windows XP Professional 'eHow.com
    Nov 11, 2010 | Microsoft Windows XP Professional for PC
    Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
    It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
    If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
    Error: x64.exe not a valid Win32 application This article applies to:
    • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
    • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
    • Java version(s): 6.0
    SYMPTOMS
    While trying to install Java a user gets an error message similar to:
    ' ... x64.exe not a valid Win32 application'
    CAUSE
    The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
    SOLUTION
    User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
    Follow these steps to download 32-bit Java
    1. Go to Manual download
    2. Click Windows XP/Vista/2000/2003/2008 Online.
    3. The File Download dialog box appears.
    4. Choose the folder location.
    5. (Save the file to a known location on your computer, for example, to your desktop).
    6. Click Save.
    7. Close all applications including the browser.
    8. Double-click on the saved file icon to start the installation process.
    Nov 07, 2010 | Computers & Internet
    Java installation problem
    How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
    Error: 25099 during Java installation This article applies to:
    • Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
    • Browser(s): All Browsers
    • Java version(s): 6.0 , 6u10+
    SYMPTOMS
    While Java installation is in progress, a message box with the following error is displayed:
    Error 25099. Unzipping core files failed.
    CAUSE
    The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
    WORKAROUND
    Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
    Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
    Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
    Step 4 : Download and install Java.
    1. Go to Java.com
    2. Click on the Free Java Download button, and start the installation process.
    Nov 08, 2009 | Computers & Internet
    Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
    WORKAROUND
    1. Go to Java.com
    Sep 17, 2009 | Microsoft Windows XP Professional With...
    Can you install java or windows on cect 168
    If you havent purchased this phone yet let me recommend an I9 phone same style better firmware and it comes with JAVA 2.0 installed already. As far as windows you cant install on these cuz they are not true Smart Phones. Do some reaserch on these before you buy. They offer a smart phone bu they are alot more expensive.
    go to mycellbay.com or ebay
    Mar 30, 2009 | Dual Electronics CECT P168 Cellular Phone
    Open Questions:
    Computers & Internet Logo
    122 people viewed this question
    David Payne
    David Payne
