Question about Stanton Sk2f DJ Scratch Mixer - Good System
STANTON SK-FIVE MIXER HOOK UP
MY TURNTABLES MAKE A BUZZ SOUND WHEN I AM USING THEM...I AM USING THE STANTON SK-FIVE MIXER AND I AM NOT SURE IF THE HOOK UP IS RIGHT...CAN U HELP?
  • 69 Answers
Are the gnds connected(earths) you get a buzzin noise if not earthed
Posted on Aug 06, 2009
  • sam brown Aug 06, 2009
    check leads and connect all gnds
Loud buzz from deck, seems to be coming from RCA cable
It seems that is bad grounding of the gear, check i everything is conected to ground. I can also be the quality of the cable, Bad cables can produce a lot of noise, try using other cables.
Apr 07, 2015 | Technics SL-1210 Turntable
I am having problems with one of my stanton str8 100's. I am only getting sound out of left channel. Can anyone help me with this?
Firstly check all your connections. If that doesn't solve it remove the wires to the cartridge. With the amp on - touch each wire one at a time with your finger. With one of the wires you should have a buzz on the right and with another a buzz on the left. If you do it shows that the signal is getting to the amp. But what it means is that either you had a bad connection to the cartridge or the cartridge has failed.
Oct 29, 2013 | Stanton STR8-100 Turntable
Stanton deck issues
Does decks are too bad build, i gave them away
Jul 23, 2012 | Stanton ST-150 Turntable
Technics 1210 poor sound
it must go in to a mixer,if you have then the channel select on the mixer is wrong.
Jul 05, 2012 | Technics SL-1210MK5 Turntable
I received the turntables and mixer but Im having trouble installing everything together. Is there any companies that can help you install the turntables, mixer, and speakers
Not to worry if you can take some pains and be confident. First of all arrange the turntable, the mixer, the amplifiers and the speakers. Connect the turntables two RCA pins to the PHONE pins L and R. of the mixer. Using another set of RCA cables to connect the output of the mixer to the amplifier's AUX inout L and R. Try to connect the red and white in accordance to the L&R. The speakers should be cconnected to the left and right of the amplifier's main. if you have front and rear use them but connect with the polarity of the red and black polarity . Use a good power supply multipin unit to connect all the power. Do not switch on until you have checked once again. Now switch on and play your favourite record. DO take time to do and you will suceed. Good day
Jul 11, 2010 | Stanton ST-150 Turntable
There's only sound in the left speaker.
when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 24, 2009 | Stanton STR8-30 Turntable
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
193 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
