Question about Remington Precision HC-8017 Hair Trimmer
Remington HC600 - my blades are pulling my hair when cutting, happened for the first time last week - machine is about 5yrs old?
Can I find a repair set (HC600 Blade set) now? Thank you
Posted on Feb 14, 2015
  • Remington Master
  • 1,610 Answers
You may need to replace the blades. You will find replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-hc600-hair-clipper-replacement-blade-set-p-847.html
Posted on Sep 15, 2010
Clippers have suddenly stopped cutting and seem to pull at the hair
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Apr 13, 2011 | Oster 76076-010 Hair Trimmer
Would not cut hair sticking all the time maybe need new blades
if you have not already tried this, the first thing you should do is lubricate the blades. you can get shaver oil at any salon or beauty supply store.
Jul 03, 2010 | Remington Precision HC-8017 Hair Trimmer
Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Jul 17, 2009 | Remington HC-600 Hair Trimmer
Blades do not cut on the remington hc8017 trimmer they just pull the hair
Try cleaning the blades as they maybe clogged with hair.
Oil them regularly to prevent seizing.
Jun 18, 2009 | Remington Health & Beauty
Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Apr 11, 2009 | Remington Health & Beauty
Remington HC-921 Mens Clipper Kit Pulling hair not cutting
no but I can't wait until someone does- having same problem. They worked fine then didn't
Mar 29, 2009 | Remington Health & Beauty
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Remington HC600 hair clipper stopped clipping
To all of you: adjusting the screws won't help, unless you screwed something up yourself, of course LOL The same problem bothered me a few years, and an hour ago I found out it could easily be a single hair stuck between the blades, thus separating them a bit. Get rid of it and the trimmer will probably work again. It can even get out spontaneously, which happened to me and kept me wondering what was going on.
P.S. DON'T lubricate unless you are required to (check your manual) The model I have (HC210c) does't need lubrication, I guess yours is similar to it. And remember that NOT every oily substance is a machine lubricant.
Jun 28, 2007 | Remington HC-600 Hair Trimmer
Remington Precision HC-8017 Hair Trimmer Logo
1,122 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
