Question about Daewoo Heating & Cooling
Compresser faulty need to replace outside unit
  • 144 Answers
Sorry you can no longer just replace the outdoor unit unless you are useing 410a freon r-22 has been discontinued and they no longer make these units they are a few still around but its diffuclt to find now you have to replace the whole system or just the compressor the epa decided that r-22 is destroying the ozone and this is the best way to resolve the problem they predict parts will still be around till 2030 if my info is helpful please give me a rating and or a vote
Posted on Sep 14, 2010
Wat is H3 error in bluestar split Ac?
Hello Yogesh...
Unless you are familiar with the BASICS of REFRIGERATION...
"H3" ERROR CODE means it is "Out of ORDER"...
Broken: Needs repair.
By searching the internet "split A/C " It defines a
COMPRESSOR overload protection is trying to
SAVE your equipment FROM SELF DESTRUCTION.
See second detail sheet (below)
"COMPRESSER"
Is the heart of MOST modern refrigeration systems.
In a SPLIT system it is the outside unit with the FAN
that should be running when the COMPRESSER is
in action. Typically then compressed & COOLED
REFRIGERANT is then piped into a cooling element
EXACTLY LIKE MOST REFRIGERATORS where the
cooling takes place (expansion valve and evaporator).
Treated AIR (indoor) is then blown through the
evaporator... cooling the room and warming the
refrigerant (which continues to cycle back to the
outside unit where the compressing cycle
continues until the INSIDE temperature is
achieved... (thermostat on the wall)
"COMBINED"
pretty much means EVERYTHING but those combined refrigeration units seen WORLD-WIDE HANGING OUT OF WINDOWS... or on roof-tops with DUCTING for
"treated AIR" to be pumped where needed.
Similarly heat pumps simply have reversible valves...
which turn the coils around (functionally).
There too are split-system (inside/outside) & combined units.
Excellent refrigeration primer (below)
https://camec.com/cameccatalogue/documents/000948_IbisTechManual1.pdf
Alarm Codes
Gree Air Conditioners Error Codes
Hope this helps.
Carnac the Magnificent
May 13, 2017 | Heating & Cooling
Is the condenser inside the unit
In a window unit the condenser is in the unit and is at the back of the outside section. With a split system or whole house cooling unit the condenser is always outside. The condenser compresses the cooling gas after it picks up heat from the inside evaporator, and forces the heated gas through a coil with a fan blowing through the coil to drive out the heat. A gas can be compressed, but the amount of heat it contains remains constant. A compressed gas will be hotter than non compressed.
Jul 26, 2015 | Heating & Cooling
CODE ERROR 100 SHOVING IN I R 3300 CANNON XEROX
You may need to replace the laser, it may have failed, this is from the service manual
E100
0001 The BD signal is not detected 10 times or more within 10 msec in 5 msec
after the generation of the laser drive signal.
0002 While the laser is ON, the BD signal cycle is outside a specific range 20
times or more continuously.
0003 While the laser is ON, the horizontal sync signal cycle is outside a specific
range 20 times or more.
Main cause The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The
laser scanner unit is faulty. The DC controller PCB is faulty.
Action
1. BD PCB
Try replacing the BD PCB. Is the problem corrected?
YES: End.
2. Laser scanner unit, DC controller PCB
Try replacing the laser scanner unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
anual.
Aug 30, 2014 | Canon IR 3300 Digital Copier
OUTSIDE UNIT IS NOT ON - INSIDE BLOWER IS WORKING Circuit at fuse box seems to be ok - not sure how to check outside boc (Breaker UD35F2)
Doc, the outside compressor could be low on refrigerant gas or the condenser switch in the outside unit is faulty. One of the things that is most overlooked is a faulty wall thermostat. For now, it's a process of elimination to troubleshoot and solve the problem.
Jun 29, 2011 | Ruud UAMB030 Air Conditioner
Is the fan on the outside unit supposed to turn when the heat is on or only for the air conditioner? Our unit is omitting a strange odor and the fan will not move even if we switch the unit to air...
The outside fan is used when ever the compresser needs to be cooled. So depending upon the outside temp as well as the temp of the refrigeration, it may not come on. When you say "our unit is ommiting a strange odor" are you refering to the outside condenser? or from the air handler? and what does it smell like? Please give us more to work with to be able to help you. Yes there are people looking and working on problems here at Fixya.com.
Jan 22, 2011 | Ruud UAKA042 Air Conditioner
Leaking from inside unit
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Jan 15, 2011 | Carrier Heating & Cooling
My outside a/c condensing unit's fan runs, but inside vent air is not cold. compresser may not be running. inside vent air was cold last week. Janitrol ckj361ab is model # of outside unit.
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Jun 17, 2010 | Heating & Cooling
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
Fan is working on inside unit and also on compresser unit outside, but compresser does not produce cold air. The air conditioner is an Airforce easy fix 12000 btu pack.
you are most likly short or out of refrigerent which mean you have a leak somewhere find a refirgeration mechanic.. if need be fill it with nitro to find the leak
Jun 29, 2009 | Heating & Cooling
AC unit
if its a a window unit suspect a faulty fan capacitor or bad fan motor same with outside, if it ain't moving or turning on the fan is faulty or the capacitor is faulty
Apr 18, 2008 | Bryant 463AAC008BA Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
