Question about Sony UP DR100 Thermal Photo Printer
UP-DR100 cannot install port - error message "target device cannot be found"
i have just bought a second hand laptop on windows xp to run my sony up-dr100 printer. i use an adaptec usbxchange scsi-usb converter and the printer installs and works no problem on my other xp laptop.
however, on the newer laptop, everytime i try to install the port, i get the error message "target device cannot be found". when the printer is attached, windows finds the printer and installs it as a generic printer. this is the same on my other laptop and it works fine.
any ideas how i can get the newer laptop to install the port?
thanks
  • lmqm4 Aug 23, 2008
    I need cd software
  • spencamp May 22, 2009
    i have a similar problem. the sony i have hooked up now works fine. when i unhook it and hook up the new(used) one, it installs it as a generic printer, but the laptop doesn't recognize it. what do i have to do? i don't have any software for the 2nd sony. do i need it? i started it before the laptop, but it still doesn't work.
    Problem Solver:
  • 17 Answers
I have a question does the first lap top still use the usb cable? if not: 1) the cable is crappy  2) the printers ports my have malfunctioned
If it is: (common mistakes) 1) the second computer doesn't have drivers for the usb  - the first laptop may be running on an older service pack so it can bipass the cord. 2) you turned the computer on before the printer.
Posted on Mar 12, 2009
I have purchased lenovo g570 laptop and installed windows xp in it but i m unable to install audio drivers in it. i have downloaded the audio from the website, while installing it is showing the message...
Sounds like you've downloaded the wrong driver. Make sure you download the driver that is for your operating system. If you purchased the lenovo and installed windows XP, what did it have on it when you purchased it, because all systems come with an operating system, unless you bought if from a jack leg or second hand where they wiped it.
Mar 28, 2012 | Lenovo G570 Notebook
I have a lenovo G550 Laptop . I have installed Windows xp Sp2 , all the drivers got installed Successfully , But when I try to intall Conexant Audio driver Then after Some Seconds IT displays an error...
if you cannot install the sound driver, then the next best solution is
Buy
"USB Sound Card"
from Ebay for 1$
connect it to the USB port and connect the sound cables to the audio port in that....
May 09, 2010 | Computers & Internet
"error loading operating system"
Sounds like your Windows XP installation failed. Run the XP install again making sure to delete the existing partition and then create a new partition. You could also have a bad drive out of the box.
Sep 15, 2009 | Dell Latitude D600 Notebook
I have a Toshiba Satellite A215-S7437 series. The system loaded up fine for the first day then I loaded it today and I get an error message stating that there is a "failure imminent" and I need...
hi vista is extremly un compatable with either satellte or cable boxes and even printers,and many other devices,if you must use a pc to flash a box etc then buy a cheap old desktop with windowsxp and a seriel port(no hassles then)good luck.
May 07, 2009 | Toshiba Satellite A215-S7437 Notebook
USB Hardware Installation Problem
Try the following:
To fix the Error 13: Data is invalid problem, go to Start, Run... and type "REGEDT32.EXE" without the quotes to run the Registry Editor. Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ENUM\PCI and you will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04".
Under each of these folders will be another folder with a long numerical name.
Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install.
HIGHLIGHT THE ENTRY "VEN_xxxx" for that device and select 'SECURITY'-'PERMISSIONS' FROM THE WINDOW TOP MENU and then tick "Allow" for "Full Control".
Close REGEDT32 and then continue with the installation of your device.
This wil lremove the Error 13: Data is invalid from your wnidows 2000 / 2K / XP system. Repeat this for each hardware device you get the Error 13: Data is invalid problem with.
Jan 14, 2009 | Dell Inspiron 6400 Notebook
D3DERR_NOTAVAILABLE
its direct 3d driver: you need to reinstall the last version of directx, or perhaps your videocard driver before
Nov 21, 2008 | Microsoft Windows XP Professional With...
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
How to install windows xp over utubut?
habibi,
to install XP:
1). you must have Windows XP setup disk.
2). If your HDD is SATA interface then error message will be raise...No Hard Disk Found. To fix this problem goto BIOS setup and Make SATA disabled. then try to install.
For more help just Ask me.
Thanks
Iqbal
Apr 02, 2008 | HP Pavilion dv6000z Notebook
Ipod shuffle 2nd gen
there could be a problem with your usb port...try another port or try another device in same port...also could be the connecting cable for ipod....
Jan 01, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Sony UP DR100 Thermal Photo Printer Logo
363 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
