Question about Toshiba Satellite A100-S2311TD Notebook
Boot up problem
Having trouble with my Toshiba Satellite A100-033 laptop. It refuses to boot up properly - or rather it tries to for two seconds, turns off then tries again for two seconds, turns off, etc, etc, etc. Any ideas?
  • duncur May 15, 2008
    Thanks for that but none of those seem to work. The recovery wizard just goes straight back to the problem. Any other ideas?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
You need to press f9 while its loading then go to command prompt, you want to then type in command bootrec.exe
then bootrec/fixboot and ten bootrec/fixmbr ....sometimes its just bootup and other times it will be drivers or dhll files causeing your computer to not want to boot, if you have vista you can press the f9 at startup and go throught the recovery wizard there are plenty of options there, i tend to have the same problems, but sometimes if i have something hooked into my usb ports it causes the boot up problem, so i unhook everything and reboot and it works.
if you need any more information you can message me at vmhreha@aol.com i have a ton more options you can do if this one i just gave you doesnt work.
Posted on May 15, 2008
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
Format problems
change the boot order in the bios and set the it so the cd is read first
Jun 07, 2010 | Toshiba Satellite M45-S165 Notebook
Have a Toshiba Satellite M40 I'm trying to work on for a client and having serious trouble... I have the original restore cd and a legitimate Win xp Pro cd and the machine won't boot off either. It just...
try holding f2 or f10 at boot, right when you turn it on, and hold it in until you get into bios or a boot selection screen. then you need to set the cd drive as the primary, only boot device for the time being
May 21, 2010 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
I have a Toshiba Satellite L355-S7811 laptop that will not boot. It keeps going to a blue screen that says fatal error and before I can read it,it restarts. I dont have a recovery cd so I dowloaded 2 from...
See let me talk with you from experience...
The only thing that can be done is system restore to factory default and remember to backup your documents.
This is the only way to resolve the problem you are going through.
Cheers.
Oct 11, 2009 | Toshiba Satellite L355-S7811 Notebook
Hi i have a toshiba satellite laptop and im having some issues and need to format the hard drive how would i get windows of the hard drive because as you know they don't give you the cd
there area couple of ways that this can be done but before you do anything make sure that you have a windows installation cd, if you dont try and get one. one thing that could be done is you could format the drive in the recovery console using the fdisk command (must know how to operate a command prompt), or you could boot off of a windows installation disk and format that partition, and then follow the rest of the steps to reinstall windows. also if you need to get files off of the computer you can simply download a program called bart pe, it is a very small operating system that you put on a cd and boot off of. it gives you a GUI so you can backup all the files that you need without having to boot into windows and have trouble.
Sep 16, 2009 | Toshiba Satellite A135 Notebook
Laptop won't boot from recovery disk
Remove the battery and AC adapter and then hold down the power button for 30-45 seconds then try booting again
Jan 24, 2009 | Toshiba Satellite A25-S307 Notebook
Boot up problem continues
Looks like you will have to replace RAM modules.
May 15, 2008 | Toshiba Satellite A100-S2311TD Notebook
Boot up problems.
sometimes new RAM and old RAM develop some kind of compatibility issue due to slight variations in them.... it is something like the system gets accustomed to what it was before and refuse to adapt properly to change...
please take some experts advice....
Jan 31, 2008 | Toshiba Satellite A135 Notebook
Won't boot up
A bit more info would be good. Did it shut down normal. can you enter bois. any messages???
Dec 06, 2007 | Toshiba Satellite M115-S1061 Notebook
Toshiba Satellite A100-S2311TD Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
