Question about Samsung HT-P10 Theater System
I Have samsung HT-P10, Pl let me know the laser lens number is used for the same or let me know any satiable lens which can be used for HT-P10
Hi.. my home theater system HT-P10.... is not working.... Any of its function do not respond after it being kept on...! Any of its function are not working.... the dvd player doest open up.. nor sound comes out of auxiliary, radio or any other function... and the 5.1 display is never shown.. it shows 2 channels only..
and this had been the problem frm last 1year.. at the beginning of the year... it was working suddenly in between and at times it use to turn out inactive but from last 6-7 months it is totally inactive...!
I contacted and the guys came down to my house telling that we dont hold any spare parts of system we cannot do anythin...a do they say we do not repair...!
So what to do to repair it.. can it be..? nd can i ever use its sond sytem only.. in any form.?
Posted on Oct 02, 2010
My samsung ht-p10 home theater system displays "No Disc"
..I would assume that you have carefully cleaned the lense and inspected the flexible ribbon cable..try replacing the spindle our case they are not expensive..good luck Elben
Aug 24, 2012 | Samsung HT-P10 Theater System
The lazer leans not working
If this is confirmed then the OPTICAL HEAD must be replaced with the same type. Before this is done you can clean the lens as a last attempt.
Use all precaution when replacing the head, need to remove the static shorting in the new head before replacing. Take help.
Sep 10, 2011 | Samsung HT-P10 Theater System
This problem is with my home theater HT-TZ512. The disc sometimes loads, plays for 15-30 minutes, then randomly stops. The picture is still on screen. It looks like I pressed the pause button. When I...
You need to try a DVD Laser Lens Cleaning Disc.
If this doesn't work then you'll need to remove the cover and clean the Laser Lens with some Lens Cleaning Fluid and a QTip. Just use a few drops on the QTip and then wipe over again with a dry one.
If the above fails then its the Laser that's failing which isn't normally cost effective to replace.
A good way to check is if it will still play CDs but not DVDs then its the Laser.
Jun 11, 2011 | Samsung HT-TZ512T Theater System with...
My HT-P10 displays "protection" and
The amplifier has a bad channel or is bad in general, and will need replacing. In some cases, it's a separate board and can be replaced itself, but in others, everything is on one board(except the power supply unit) and warrants just having he unit replaced.
Dec 04, 2010 | Samsung HT-P10 Theater System
Samsung HT Q20 dvd player saying No DISK
1. Try cleaning the drive laser lens with a CD lens cleaner.
2. You need to check servo parts, spindle motor and pick up flat cable.
3. Clean laser lens manually.
Oct 25, 2009 | Samsung HT-Q20 Theater System
You could try cleaning the drive with a dvd cleaner disk and also a can of compressed air to blow into the drawer. It may just be dirty. Good luck! I hope this helps you.
Aug 27, 2009 | Samsung HT-P10 Theater System
Unable to read/play DVDs
You may have a dirty laser lens on the slider assembly. If you clean this little lens, and the problem still happens, it is an indication that the laser is getting weak and it may be time to start looking around for a new player/recorder. Good Luck
Jul 14, 2007 | Samsung HT-DS610 System
Used lens laser lens cleaner & now player won't play.
You can open the dvd and try to clean it the dvd so you can see the lazer.take a normal earbud and wet it with normal methylated spirits and clean the lazer gently with that.the lazer cleaners hardly ever work 100%.Just remember not to push to hard on the lazer or you will brake it.gently clean and wait for lazer to dry and try again.
Feb 19, 2007 | Samsung HT-WP38 System
DVD player not playing DVD's
Yes. The laser lens in your player is dirty or failing. To fix your problem, try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail stores.
Nov 30, 2005 | Samsung HT-DB120 System
Samsung HT-P10 Theater System Logo
372 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
