The start delay flashes in the middle of a cycle on a hoover washer dryer nextra 6 . it drains but doesn't spin
  • Washing Mach... Master
  • 17,130 Answers
Program error due to maybe a delay in the fill and drain cycle, Get the inlet and outlet valves cleaned( drain should be quick)
Now if during the cycle the program is cutting off voltage to the motor, then the control board can be faulty.
Check if the drive is having connection fault to stop the motor voltage.
Posted on Sep 14, 2010
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Delay start light is flashing and door will not
It is your control board that has failed. It is time for a new machine. It is a common problem. If it's under warranty get it fixed but the machine is starting to wear out.
Unplug and wait for a clicking sound this will be the electronic door lock releasing.
Dec 12, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Washer keeps stopping and is still full of water and the delay start button is flashing
Drain pump is either blocked or failed. Check the pump filter which should be at the front right of t he bottom of the machine. If this is clear, you may have to remove the pump to get debris out of the pump housing. Ly the drain hose on the ground to drain the machine first and unplug before going at it.
Dec 08, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
308 people viewed this question
Top Washing Machines Experts
