Question about Ricoh Office Equipment & Supplies
Sc 990 ERROR PROBLEM ON RICOH 2045/2035. how can i solve this problem..
  • 21 Answers
Replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Posted on Oct 21, 2010
  • 126 Answers
Replace the hard disk drive of the copier.
Posted on Oct 01, 2010
  • shramik tripathi Feb 13, 2012
    replace fax board
  • Vagner Cristiano Bulling Maciel
    check the id sensor and clean and check the laser power sp-2-103 for patern, this problem occur becouse the id sensor no detect gray scale in the drum
3 Suggested Answers
SOURCE: Ricoh 3050 printer, Error 990
We got the same error on our machine, so I called Ricoh Direct Tech Support and they said it is a known manufacturer's error. All you have to do is 1. make sure your product is registered, 2. call them up and tell them the error and 3. they will send you a new machine. You will have to send back the old machine in the same box, but they provide the RMA for you to ship it back in.
Good Luck!
Posted on Jan 09, 2009
  • 903 Answers
SOURCE: service SC 990 RICOH
sc990 is a general software error. It could be caused by a specific application or function, or it could be caused by a problem with the process control. In general, you can get rid of the sc990 error by turning the machine off with the main power switch (the orange switch on the left side of the copier) but if the error comes right back, the best first solution is to update the machine's firmware.
Posted on Nov 25, 2010
How can i find the firmware to fix error sc 990 of ricoh 2075?
Contact your nearest Ricoh service center, don't try anything by yourself you may incur controller damage
Dec 25, 2015 | Ricoh Office Equipment & Supplies
HOW TO CLEAR SC 990 MESSAGE IN RICOH AFICIO 2022 APPEARS WHEN SWITCH ON THE MACHINE?
Hi
I have found this explanation of the error message:-
Description: Software performance error
The software attempted to perform an unexpected operation
Causes: • Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here:
Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
My ricoh aficio code a 990 how to fix them ?
An SC990 is usually an error indicating maintenance is overdue. The only way to verify that is by printing out the SMC report and seeing the subcodes. In the case of this model when is the last time the drum and developer was replaced?
Nov 15, 2014 | Ricoh Aficio 1015 All-In-One Laser Printer
Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Apr 23, 2013 | Office Equipment & Supplies
Code sc 990
sofware error, if your machine has A hard drive then format it, if that does not work then update the board firmware, also check the memory, one of those will solve the problem
Oct 29, 2012 | Ricoh Aficio 2027 All-In-One Laser Printer
IN RICOH AF 2045 SC 990
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
Hi, My Ricoh 1075 photo copy machine is giving error sc 990, any help will be much appreciated. Please replay back soon
many causes can do sc 990
which are :
soft ware problems .
hard disk problems or bad connection
printing interface problem .
so you can
first :
make shore that the printing interface is connected correctly
tray to replace the hard disk
tray to set up new soft ware useing flash card.
if it is still do
e mail me on :
lotfekamel@yahoo.com
Oct 29, 2010 | Office Equipment & Supplies
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
A ricoh 1045 sc990 code says about Hard Drive problem. Where is this located? also please tell me what is and where is located a developer? Thanks in advance.
SC 990 is a software performance error.The software attemted to perform an unexpected operation.Software defective,internal parameter inncorrect or insufucient working memory.SC 990 occues when printing a message dtored in the information box.Avoid by firmware upgrade.This information can be cheked by using SP 7-403.The hard unit is located in rear right side up position of by pass.The developer is under toner botle in developer unit.
Aug 01, 2009 | Ricoh Office Equipment & Supplies
1,924 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
