Question about Acer Computers & Internet
The power button light is glowing without charger. But the window screen is not coming in the display.Literally Iam not able to ener in
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
There is a possilblity that the LCD might have gone bad.. If you have a external monitor or a TV that can be connect with the computer, connect it and check if the display is fine in that.. If it works on the external monitor replace the LCD kit.. If its not working thn install th video drivers...
Posted on Sep 14, 2010
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
CAN'T POWER UP NEW COMPUTER
Do any lights/LEDs glow when the unit is plugged in? If not, you could have a bad charger or battery, If you do see blinking or glowing lights when plugged in, but no display (and you are sure the on/off switch is in the on position) try hooking up an external monitor to see if the built in screen is faulty or even deselected from use. It is possible, if you do in fact have power, that a bios message cannot be displayed on the built in screen.
Dec 30, 2011 | HEWLETT-PACKARD Computers & Internet
My Acer mnitor won't stay on. The power cord works, when I unplug it from the black power box, hte light that indicates the power supply is working comes on and stays on. However when I plug into the
It is Windows 10.
I have reverted my machine back to Windows 8.1 and its working perfectly.
As long as you haven't had Windows 10 on your machine for 30 days you can revert back to Windows 8.1.
First of all open Settings and click Update and Recovery
Now in Update and Recovery window click on Recovery option. This will open a list of 3 options on the right hand side. You need to look for "Go back to a previous version of Windows" option. To start the process, click Get Started button under this option. It will ask you to plug in your charger before allowing you to continue.
Make sure your battery is fully charged, because before you press the get started button you need to place the cursor over the button and plug in the charger.
Once the screen goes black press the keypad which should then click the button.
Wait a few seconds and then unplug the charger.
All being well the process will now continue without the charger plugged in.
Once you get to the restart screen it should be safe to plug in the charger and you should then still have a screen you can see.
Hope this helps.
Dec 28, 2017 | Acer AL1916W 19" LCD Monitor
Iam unable to turn it on, any help would be great
does the light come on when you plug in a charger? if so try turn it on with the charger in and on. and hold the power button for at least 5 seconds, if theres a light to indicate charge then theres power to it but could be some other fault internally, you have to try the tablet with the charger in and hold the power button for 5 seconds and you can leave the charger plugged in for an hour to see if it says charging just incase its a bad battery.
Oct 16, 2011 | Coby Kyros Internet Touchscreen Tablet...
I pushed the button to turn on my lap and the lights come on but the screen is black, i hear it churning but no screen rev_mbrown@msn.com
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP G60-120US Laptop
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
The display isn't coming on and there are two lights blinking aroung the key board
Aug 28, 2010 | HP Computers & Internet
COMPAQ screen fails to light up
Here issue is not clear, like if the issue is
1. There is no display on the notebook even though power LEDs are glowing?
2. There is display but very dimm/dark to see the display?
I will explain both the senarious, if the issue is something diff other than the above mentioned two, then you should get back to us by elaborating on the issue.
Solutions:
Sol: If this is the case, then try power drain:
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
If the issue persists, then the issue would be with the motherboard components, you need to contact service center
sol: If this is the case, then connect the external monitor to the notebook andcheck for the issue.
If the display is fine on the external monitor, and if you can see the display on the notebook screen by using the flashlight, then the issue will be with the back light of the notebook screen. Here also you have to contact service center.
Please reply if you need any further information on this issue.
Aug 09, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
