Question about Samsung Washing Machines
I have a washing machine Samsung R1045AV. Display shows Error HE2 or HEZ what does it mean?
SOURCE: Error code SD
This is the "suds" error code. Apparently it means that the machine has detected a high level of suds in the washer, so it temporarilty stalls to let the suds die down. You can fix this by starting the cycle over, and just use less soap in the future. It happens a lot when you are washing towels for some reason...
Posted on Mar 10, 2008
barkencoa
  • 3463 Answers
SOURCE: fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
  • 127 Answers
SOURCE: gorenje washing machine on display shows F31. what
it means"The connection to the tacho generator is open or short-circuited". that means the motor is not turning. 99% it is the brushes (20 eu) and it wil work again.
marko
Posted on Aug 13, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
kapishtech
  • 2272 Answers
SOURCE: Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 11, 2010
Kenmore HE2 Plus fronload washer is showing F- as an error code. there are no numbers in the error code. just "F-" i cannot figure out what that means
press and hold the power button until the machine resets,then if machine resets, ok. but if machine shows a fault it should give a full fault code.adrian,,,,,,,
Jan 24, 2015 | Kenmore HE2 Plus Front Load Washer
I have a error HE2 please can you tell me what it means
This means you have a heating element error! This is usually for Samsung machines.......... Unless you are mechanically minded you will have to call out an engineer!
Sep 18, 2014 | Washing Machines
Samsung wd1102xvm what does error code he2 mean?
1) jammed key, proceed according.
see your instruction manual or call to customer service, and get help by online via chat.
God bless you
Jun 21, 2012 | Washing Machines
Samsung washing machine WD0754W8E
In the Samsung wd0754w8e "HE2" can mean that one of the two thermostats mounted in the top manifold (wired to the active and neutral wires of the element) is open circuit. One is resettable, the other is not and will require replacement if it measures open circuit at normal ambient temperatures. Both thermostats have been very problematic in my samsung front load washer / dryer.
May 06, 2012 | Samsung WF337AA Front Load Washer
What does he2 mean on my display screen whilst a load of washing is on? the load is on now, need assistance asap.
According to my list of Samsung fault codes 'he2' means that there is a problem with the heater not working ('he1' for instance is overheating).
Sorry but a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Samsung Washing Machines
HE2 front loader error code
According to the HE2 Tech Service manual, it means "Suds Lock (Overdose of detergent detected during the wash cycle).
Aug 29, 2008 | Kenmore 43142 Front Load Washer
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
