Question about Samsung Digimax S600 Digital Camera
Anytime I inserted memory card to my Samsung Digimax S600 Digital Camera it an error message is displayed saying "MEMORY CARD LOCKED". I have tried other memory card but i received the same message. How can I solve this problem?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 14, 2010
How can I find a memory card today for my Digimax S600 camera? Sandisc 4 and 16 Gigabyte do not Work
You need to use SD cards, 2GB or smaller. The S600 does not work with higher capacity SDHC/SDXC cards.
SD cards are getting a bit harder to find, but they should still be available at most department, electronics, or office-supply stores. And, of course, the usual online sources.
Feb 19, 2015 | Samsung Digimax S600 Digital Camera
How do you unlock a card in the samsung s600
If it'san inserted memory card,pull it out and there should be a metal tab on it.It slides back and forth,1 position is lock,the other position is unlock.Slide it to the other side.If that is not your problem as I understand,just reply back here and I will get an auto link to your post.Greg
Sep 04, 2010 | Samsung Digimax S600 Digital Camera
The Digimax S600 keeps saying that the Card is Locked. And it is NOT locked. What could be the problem?
The component that covers the lock switch inside the camera may be stuck in Lock position. May be fixed by opening the camera up and releasing it from Lock position. Not recommended if you still have warranty on it.
Jun 29, 2010 | Samsung Digimax S600 Digital Camera
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
May 11, 2010 | Samsung Digimax 4010 Digital Camera
Memory card locked
Hi..
To unlock your memory card you need to remove it first. Look at your memory card you can see them a small button square you need to slide it. After that insert it back to your camera, try to use what will happen.
Hope it may helpful for you!!
ICmanServer
Jul 31, 2009 | Samsung Digimax S600 Digital Camera
2gb memory card wont work in samsung digimax 4010 digital camera
this is an older unit, when this unit was manufactured, 2gb memory cards were still unavailable. basically, 2 gb memory cards are not compatible with the unit, try to use a lower capacity memory card
May 07, 2009 | Samsung Digimax 4010 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
'Check SD Card' message
Looking at the manual Samsung only guarantee support for cards up to 1GB so I guess your new card won't work in this camera. Perhaps you can take the card & camera to your supplier and try other manufacturer's cards or just lower capacity.
Jul 24, 2007 | Samsung Digimax S600 Digital Camera
Samsung Digimax S600 Digital Camera Logo
238 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
