Question about HP OfficeJet K7100 Photo inkJet Printer
When i switch on my HP K700 the paper jam light remains on and when I lift the lid top the cartridges do not move to the centre of the printer.
james klgr
  • 362 Answers
SOURCE: X1270 - flashing light.
sounds like the paper jam might have stripped some teeth off the gears in the printer or the motor might have failed have a visual look at the gears that pull the paper through if broke measure it and tell me how many teeth it has i might have one, or even the motor i have extra printers lexmarks for parts.
Posted on Dec 24, 2007
SOURCE: 381 Paper Jam Error
I had to remove every toner cartridge and drum. I found the paper under the second to last drum.
Posted on May 22, 2008
SOURCE: oki c5500 gives a false paper jam reading
service the rollers (either clean the pickup with clean alcohol or use sandpaper ) sometimes clean the fluff from the printer with dustoff helps as well
Health and Safety get an engineer to do it for you. if you have warranty call them out. check your total page count and diagnostics via printer status page before you call them out.
Posted on May 23, 2008
Ajkill
  • 2035 Answers
SOURCE: hp psc 1400 inkjet fix, paper jam
Please try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 27, 2009
Shah_Sheh
  • 81 Answers
SOURCE: My Epson Stylus DX8400 has paper jammed. I have
Have you turned the printer off for a minute or 2, this will reset the sensor which threw up the error message, often works
Posted on Sep 27, 2009
How do I get rid of paper jam that stays on even if nothing jammed
My guess is that there is a piece of paper somewhere blocking a light beam or in a contact switch.
Try a little air if you can't manually feed a sheet of paper. Use the heaviest bond you have.
Jan 06, 2015 | Canon Office Equipment & Supplies
TROUBLE SHOOTING FOR HPDESKJET 940C
You can try the following steps....
Turn on the printer and lift the top cover. Wait for the print cartridges to move to the center of the printer. Tilt the cartridges forward and carefully lift them out of the printer.
Dip a cotton swab in warm water and clean the metal connectors on each print cartridge thoroughly to remove all paper dust and ink residue. Continue cleaning the cartridges with new swabs until the swab comes away clean.
Vacuum the interior of the printer with a small vacuum cleaner like the kind used to clean and service computers. Continue cleaning the printer until no more ink residue and paper dust are found in the interior.
Wipe the inside of the printer with a soft cloth to remove any remaining residue. Reinsert the print cartridges into the printer, making sure they are secured with a click, and close the lid.
Remove all paper from the paper tray and flip the tray down so you can clearly see the inside of the printer. Direct a flashlight into the printer interior and look for any torn pieces of paper.
Grasp any torn paper firmly with the tweezers and pull it straight out of the printer. Examine the printer interior again with the flashlight to ensure there is no more jammed paper.
***If you need any technical help on printer then you can reach at here
Mar 06, 2013 | HP DeskJet Office Equipment & Supplies
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Paper jam light on permanently, printer is jammed
    Check the following steps for fixing Hp Carriage Jam Error :
    Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
    Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
    Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
    Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
    http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
    Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
    HOW DO I INSTALL THE INK CARTRIDGE IN PHOTOSMART C4280
    Turn on power to printer, then lift the top half of Printer lid, the cart holder will move to centre, place printer cart in the holder rack, press firmly in place.
    Jun 07, 2010 | HP PhotoSmart C4280 Laser Printer
    HP DeskJet 812C Hardware Problem! with Printer cartridge carriage. Printer Cartridge retracted into right side of case will not come out. There is No paper jam in machine to prevent it from doing so. ...
    Disconnect the "data" cable (parallel or USB).
    Disconnect the "power" cable.
    Reconnect the "power" cable.
    Turn the printer on.
    Lift the printer's lid -- the print-carriage should slide the printer-heads to the "middle" position.
    If all else fails, take the printer to a qualified technician, for more trouble-shooting.
    Feb 02, 2010 | HP DeskJet 812c InkJet Printer
    The power light and the paper light are blinking continuously.
    turn off the printer open the lid move the cradle back and forth then move it to the middle, close the lid turn it on let it warm up and open the lid the cradle should move to the center, it sound like the home position senser might be going out or it is just ouot of wack.
    Jan 25, 2009 | HP DeskJet 810c InkJet Printer
    Failure to print
    Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
    J
    Aug 29, 2008 | HP DeskJet 932c InkJet Printer
    HP 3820 Deskjet Printer
    1) take a flash light and inspect the paper path just to make sure there really is nothing there.
    2) print a test page from the printer by pressing the big button ( I think) one of the buttons, can't remember I work on so many models
    3) take out cart. turn off then on, install cart. and do step 2
    what happens
    Jan 04, 2008 | HP DeskJet 3820 InkJet Printer
    Dec 08, 2007 | Lexmark X1270 All-In-One InkJet Printer
    HP OfficeJet K7100 Photo inkJet Printer Logo
    216 people viewed this question
    Seeker5211
    Seeker5211
