Question about Black & Decker BR300 3''x18'' Belt Sander
What size sanding belt does a performance pro 710w clm710bs belt sander need
mikeymiddles
  • 58 Answers
SOURCE: Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
comax
  • 154 Answers
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
SOURCE: what is the belt size of a skil 593 belt sander?
2 1/2" x 16"
Posted on Sep 13, 2010
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
Sep 03, 2011 | Electric Power Belt Sander, 3" X 21" 700...
I have a Skil Belt Sander 405. I bought at a sale. How old is this sander? How can I get a belt for this sander?
http://cgi.ebay.com/4-x-21-3-4-sanding-belts-36-grit-qty-10-/310329120043?pt=Sanders_Sandblasters&hash=item48410e952b
this is the type of belt it uses (size rather) 4"x21 3/4" you can find them on ebay.
http://www.skiltools.com/en/ here is the official skil website. they can probably email you an owner's manual if you wish
hope this helps out. this one is vintage from what i understand
thanks,
mike w
Jul 07, 2011 | Skil Tools & Hardware - Others
Need drive belt fpr br300 elt sander
if you do not find it, you could change one of the pulleys, with one of greater size, of course this will affect the speed, but is an alternative.
Apr 12, 2011 | Black & Decker BR300 3''x18'' Belt Sander
What size belt does it use
You did not mention a model number, but the is probably the width of the belt and the 6 is probably the diamter of the disc.
The sanding belt size is probably a 4" wide by 36" long, but it may be 4 x 24" long. Put a string around the rollers, and then stretch the string out straight. Measure it and that is the belt length.
You can find either size belt at sites like http://www.2Sand.com and http://www.BuySandpaper.com
Jan 25, 2011 | Delta Machinery 4x6 Belt/Disc Sander
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Black & Decker BR300 3''x18'' Belt Sander Logo
406 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
