Question about Intel Motherboard
Does this motherboard have an onboard display/VGA
    President:
  • 2,571 Answers
Have a look at the rear of the motherboard, if it has a Blue d-sub VGA port , then yes it does.
You dont say what model you have, so it is impossible to say for your board.
If you google your model number +specs, you will get the specifications for that board
Posted on Sep 14, 2010
4 Suggested Answers
edgood1
SOURCE: vga display problem
There is one pin/wire on the VGA connector that translates to the color red on your screen. If you aren't seeing any red, I would suspect that there is damage to the integrated VGA connector on the motherboard, or a component failure in the circuit.
These are great desktop boards.
The Video bus on these boards are shared between the integrated (onboard) video card and port and the AGP slot. This means that you can only use one or the other. When you install an AGP card in the slot it overrides the integrated video including your problem.
If you are good with electronics I'd take a look at the board under the scope and look for damage.
I would rist check with intel on the warranty. You may be surprised. I've had several of these replaced via RMA through intel. They are a bit older but still by desktop board of choice.
Posted on May 21, 2008
d2704
  • 101 Answers
SOURCE: vga
try to connect PC speaker and listen his sounds for diagnostics
  1. one short - system is good
  2. one long, three short - poor video card
  3. three ore more long - poor memory RAM module.
Posted on Mar 07, 2009
darkpain
  • 316 Answers
SOURCE: my motherboard is intel original D915GAV/PGN
The leds are open?
Posted on Jan 12, 2010
Vga onboard
you may have encountered a VGA cable not properly installed to the VGA ports....try to reconnect the VGA cable,properly installed from the VGA port of the LCD to the onboard VGA port of the motherboard and restart computer... less pressure applied to each and every end of VGA connectors to VGA ports may sometimes affect the display of the screen causing to red, pink blue screen output....hope this help...
Dec 30, 2013 | Intel DH55HC Motherboard
Can't find onboard display driver. gf8200a v.1
Hello you can try this driver:
http://drivers.softpedia.com/get/GRAPHICS-BOARD/NVIDIA/ECS-GF8200A-V1-0-Nvidia-MCP78-VGA-Driver-17516-for-XP.shtml
This is for xp.
Good luck
Oct 25, 2012 | EliteGroup GF8200 MCP78S AM2+ Atx 32GB...
P5KPL-AM mb bios only four line display
Try another monitor, if problem still exists your VGA is damaged, if youre using the onboard vga then connect a PCIex vga card get into bios (suppose the display problem is solved) and disable the onboard VGA option. Keep your pc running like this (using external VGA adaptor).
Aug 03, 2011 | ASUS P5KPL-AM SE Motherboard
How i solve supermicro x8dt3-f display problem
Make sure JPG1 is jumpered between pins one and two.
Pin 1 is on the left.
JPG1 is on the very bottom of the motherboard, near the end of the PCI slot.
Next go to Advanced Setup Configuration if you can get any video, and check Boot Graphics Adapter Priority.
Make sure it is set to Onboard VGA.
If no video, reset the BIOS.
Onboard VGA is the default.
Jun 01, 2011 | SUPERMICRO COMPUTER Supermicro X8DT3...
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
I need gate performance 1400 display adaptor...any idea on how to get my display going?
good day sir, if you are talking about the onboard vga, you may need to go to CMOS setup and locate the settings in where you need to choose the Onboard vga. there are several options. PCI/AGP/PCIe/onboard, select the onboard one. hope this helps. if you have any more questions feel free to ask. thanks.
Jul 16, 2009 | Gateway (4000811) Motherboard
VGA onboard driver
dear friend
i believe you ave intel p4 1.8-3.0 or celeron 1.7-2.4 cpu
goto
intel.com
choose downloads
choose motherboards
select any board of series 865
select os
download display driver
done...
Apr 11, 2009 | Intel Motherboard
Vga display problem
May 21, 2008 | Intel D865GBF Motherboard
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Intel Motherboard Logo
14 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
