Question about Samsung (SP0411N) 40 GB Hard Drive
Victor I can't install windows on my HDD. Hutil.exe from Samsung at selftest says : Check M.C. error / abort command and erase HDD do't has any effects How it's repaer? P.S. sory for my english
    Scholar:
  • 183 Answers
Tell me 1st xp installtion had started than stoped,
than ahve a prob for bad sector in booter,
or occured with overheating cause of simultaneously writing.
so try to cool down your HDD.
THNX
Posted on May 17, 2008
HP Pavilion TX1000 Series with new 500 gb hdd unable to install windows 7, after partitions on hdd, it disappears, and unable to install os
not sure what "after partitions" means. (ah, at that point in install)
dual booting?
HP disk set
or Microsoft set.?
tell what attempting and where stuck exactly.
what screen , and what error exactly.?
new 500, new in box, new to your or new for an APPLE.
if new, really new it has mfg codes on box for any special pre-formatting...
i bet the new disk is pre-formatted. (or really not new)
seen many new disk in box with antistatic bag breached.
bingo , not really new.
what disk ,? Seagate (best)
windoz hates that, (setup.exe running)
erase the new 500
3 ways.(lots really)
1: put new 500 , as a 2nd HDD in PC #2,
2: with disk-manger delete all partitions on it. its now ready.
A: using boot windows, PE disk, do same in this PC.
B: using boot cd, boot and go to repair mode,(first screen)
then using CMD prompt mode, use DIskpart, to do that.
C: using any bood Linux, live CD same PC, run pparted and erase the partitions.
I can go more, but stop.
All windows install disk, cept w10?>
will erase any windows partitions (if you force it)
but will not do it if the format is ALIEN to MS.
Alien means not fat 16 , Fat 32/ NTFS,
Alien means Apple or other 100s of systems alien to MX.
on windows 10, it will balk with any data there what so ever.
protecting the NOOBs. cure is above.
Apr 11, 2017 | HP Computers & Internet
Windows\system32\drivers\viamraid.sys missing
If you have a windows install disk, then download active kill disk.
You need to erase the hard drive the right way, you don\'t format from NTFS to NTFS to erase a HDD.
Here is a free eraser, but you need to burn it to a **** and boot to it so it runs in DOS.
http://how-to-erase-hard-drive.com/downloadfree.htm
You can also go to Western digital and use the tools for HDD to erase.
Once the HDD is erased, your clear CMOS, reset the setting in the BIOS such as boot order, you should be able to reinstall windows and install all the correct drivers.
Apr 14, 2013 | Microsoft Windows Vista Home Premium with...
I have samsung hdd of 60 GB. I use it from last 6 years. Now i am not able to format and check disk my hdd It gives error. I used Hutil disk diagnosis software it gives 'write verification test failed'. I...
Seems like the disk is gone. 6 years IDE hard disk is somewhat old.
Now, Samsung hard disks support SMART monitoring.
Get some tool for SMART monitoring
http://sourceforge.net/projects/smartmontools/
If it shows problem for the hard disk, then nothing can be done.
If there is important data you need, you can try file recovery softwares. But I cannot say if it will work or not.
Aug 13, 2010 | Computers & Internet
Toshiba Satellite M35X-S163 Can't Be Recovered
This happens. Recovery/reinstallations sometimes takes many attempts. Only, you have to clean the CDs. Clean them with a soft cloth in + signs and not circular as one would think, CDs being circular. So, clean then top to bottom and right to left and vice versa.
Nov 26, 2009 | Computers & Internet
I'm using windows vista. petz 5 worked well at first but then suddenly i keep getting resource id = 1020 errors from the program, and it closes itself. what is this and what do i do?
Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NUpdates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i. OR user@domain.com failed an operation on
Jul 08, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
DASC Common Language Runtime Debugging Service
you most likely need Jave Runtime Installer installed
java download link
After installation try and run it again - if that does not work post back and let me know and I will try and assist further
May 07, 2009 | Video Game Consoles & Games
Harddrive problems
You may want to re-install XP with your last post. In regards with your first 2 posts. Well all I can say is Diagnose the problem well. You may have a Unrecognized Partition type. You may have a Hardware Problem Diagnose it using the following. It also includes Hard drive partitioning tools. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 22, 2007 | DFI /LAN PARTY NFORCE4 ULTRA-D/...
Samsung (SP0411N) 40 GB Hard Drive Logo
202 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
