How can I charge my cellphone with a USB cable?
    Problem Solver:
  • 18 Answers
You can charge your cell phone through the charger that is the better method. now in market multi charger avilable. you can buy one and chargr through it
Posted on Sep 14, 2010
How can i charge rechargable batteries without usb cable for GE c1433 digital camera
The C1433 is a camera, not a battery charger. It uses standard AA batteries, either disposables or rechargeables. If you choose to use rechargeable batteries, you must charge them outside the camera using a separate battery charger.
Feb 11, 2013 | Cameras
When i started using usb cable wire to charge my phone it started not to work on the charger..
try the charger pin the usb port is not able to charge the cellphone it uses to connect the device to computer
Feb 05, 2013 | Samsung Corby 2 GT S3850
MY NOKIA CELLPHONE DIDNT WORK PROPERLY
Hi:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 03, 2013 | Nokia N76 Cellular Phone
I want to charge my battery with my usb cable.
Sorry to inform you that the usb slot cable of NOKIA N70 is not intended for charging but for transferring data from cellphone to computer or vise-versa. With that, try looking for a USB cable with USB in the end, and a mobile charger at the other end. It is possible, I do have 1 like that.
Cheers!
May 31, 2011 | Nokia N70 Cellular Phone
When i connect my samsung code sch-i220 to my laptop using a USB cord nothing happens. help?
you have to install the software provided by your cellphone carrier(i,e. MetroPcs installation disk) then you must use either the original Samsung data micro USB to USB cable or a USB 2.0 compatible equivalent. The USB 1.1 cables will only charge your phone but not allow you to transfer data so your PC wont see the phone.
Sep 14, 2010 | Cell Phones
Nokia 7710 keeps switching off as USB modem
there is a problem with you mobile jack, make sure you are not using duplicate DKU2, try to use another cable installed on new usb port, other than earlier one. try to use any other phone on your pc too.
Oct 23, 2009 | Nokia 7710 Cellular Phone
USB Device Not Recognized Error?
1.connect the USB cable to Mother Board Back side port, not for extension or frontside port.
2. Check Your USB Cable...make sure usb cables are correct
Jun 30, 2009 | Cell Phones
Samsung L100 cant figure out how to charge!!! Adaptor supplied but no battery charger to plug in to mains. Do I need to purchase a battery mains charger???
you can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Jun 23, 2009 | Samsung L100 Digital Camera
L7 unable to charge
All cellphone run on Lithium Ion batteries. These batteries, by nature(physics) have a max charged voltage of 3.4 to 4VDC. So, of your charger, or USB cable, has less than about 5 VDC, then either charger is defective, USB cable(if charging from PC USB port) is not a FULL USB(has data leads only wire, 5V power wire not carried through, PC does not supply 5V power to USB because it is turned off by a PC setting option, or a non-powering USB Hub or other device is in series with PC and Phone.
Are you sure you have identified the GND wire correctly? Measurements must all be made with one lead of your VoltMeter referenced to GND. Another consideration, some Windows Mobile phones will not charge off the USB cable unless the latest version of WM ActiveSync or Mobile Device software is loaded and running on the PC. These WM phones also will not charge from just any AC USB generic charger. Charger has to be for that particular phone, or phone manufacture, to be 'recognized' before provideing charge.
The
Feb 20, 2009 | Motorola Mobility V710
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
