Question about Whirlpool Washing Machines
We have bought two days back ABM551 Professional Washing Machine . During demo, the Engineer is telling that we have to buy one additional Whirlpool Filter costing Rs 1800/- and some powder costing Rs 1800, as water quality in our house is not good. Water is hard and flaky. Kindly guide .
  • 1294 Answers
SOURCE: whirlpool awm049 washing machine
Would help if you were more specific.....
Posted on Apr 12, 2007
  • 1294 Answers
SOURCE: Maytag Performa Washing Machine
To drain out water press the 'spin only' option, if it does not work drain out the water with a tube, ie, siphon it out of the tub.
Posted on Jun 25, 2007
Timon90
  • 126 Answers
SOURCE: MY TOWELS ALL COME OUT HARD AND ROUGH
If you not use to dry towels in a tumbledryer, they become hard.
Posted on Jan 22, 2008
yalmer
  • 549 Answers
SOURCE: whirlpool awm 049 washing machine
If the washer leaks only during the fill cycle, check the following:
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During spin cycle only:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Look at the entire hose and correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Feb 07, 2008
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
Hi just bought a washing machine Whirlpool FSCR80421 and is stucked in Demo Mode. How can i exit?
Look for a reset button or contact whirlpool for the procedure to restore machine to factory defaults.
Sep 11, 2017 | Whirlpool Washing Machines
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
I have a whirlpool aquastream 9759 9kg washing machine it flashes F06 During cycle....HELP!!!!!
Whirlpool (Kenmore) 'F06' states 'tachometer failure, no motor movement detected'.
Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have whirlpool fully automatic splash model washing machine.i was told the tub of the washing machine is need to be changed because all the liquid which surronds the tub got empty due to improper...
I would not take the tech's word for this. If this is a fairly new machine, I'd call the company's 800 service number and talk direct with them.
Sometimes the local repair outlets need a little prompting from the big company. They will be able to tell you if the parts are covered.
Jun 27, 2010 | Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Changing Bearings
before starting with the your repair just try adjusting the washing machine's leg or reduce the load.
Apr 03, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
