Question about Sunbeam Classic 3957 Iron
Open Iron How can I open the iron and get into the inside. There is a part loose. Thanks
I hav a sunbeam iron i tried to clean off the bottom with a peice of candle because my jeans had stuck on the bottom an the iron stopped working warranty is out
Posted on Apr 02, 2011
  • 975 Answers
On most common IRONS , theres a screw located on the back where the main cord is , underneath it , AJ
Posted on May 17, 2008
How do i open screws
broken studs for screw tightning,cant repair without expert,there is one screw under main wire side,second is under pressure knobs to open it
Dec 18, 2014 | Philips Gc2910/02 Powerlife Steam Iron,...
Loose plate on a morphy richards comfi grip iron
Unless you want to strip it down and resecure from the inside, buy a new iron.
Jul 21, 2014 | Irons
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
Iron just stopped working, no lights, no heat no iron Opened back panel to make sure no loose wires or damage inside. The inside still looks bran new and the wire cap connectors are intact. Iron may be 2-3...
check plug fuse, if ok, check continuity of the live, neutral and earth conductors for a break. if ok, element may be faulty. Any smell of carbon burning?
Oct 26, 2009 | Irons
Cord is loose inside, strange screws prevent opening iron to tighten cords - B&D will not help if not under warranty
if the screws have a design on top , like 2 half pyramids, then they are dealer screws, so that the consumer cannot open the appliance.....if they are like introverted star shape, then these are called torx screws, can be removed by ordinary torx-bit screw driver, available at most hardware stores....
Aug 06, 2009 | Black & Decker Steam Xpress S685 Iron
Plug heating up
Check the power on the label of the iron, usually 1kw or 1200W
Next open the plug, if it has a screw. The fuse inside the plug may be too low should be 13 Amps for an iron of 1KW
Check also whether there is a loose wire in the plug.
If not the take to an electrical repairer for a quote
Jan 23, 2009 | Euro-Pro Shark GI490 Iron
Autoshut off red light keeps flashing
I had the same problem and eventually removed the tilt sensor. This is the molded board that you see when you open the back of the iron. By removing it, you will also loose the timer off function. The thermostat will still be operational.
Oct 14, 2008 | Braun SI6285 Iron
you have to open your iron to see what wires are disconnected or loose
Aug 19, 2008 | Tefal UltraGlide Easycord FV4256 Iron
Sunbeam Classic 3957 Iron Logo
520 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
