Question about Car Audio & Video
Passenger front tire wobbles when i go about 40 miles per hour to 60 then stops but the steering wheel also shakes when i put on the breaks
  • 4,963 Answers
It looks as though the tyre requires balancing.
Take it into a tyre store to be checked
Posted on Sep 14, 2010
  • Gary McCann Nov 02, 2010
    sounds like tyres need rebalanced but it is more likely to be front brake disc is warped. But yes check balance first also check the inside of the wheel for dirt and muck if so remove it.
Front end shaking bad in truck.the traction control light keeps coming on. what do I need to do to fix this
have the steering rod ends checked and all suspension points checked
have a wheel alignment done and check the castor angles
Sep 30, 2015 | Cars & Trucks
Steering wheel and tire issue
Have a front end suspension check done to eliminate any worm ball joints -shockies- worn suspension rubbers-- steering problems. If ok have a wheel alignment done and have the rear end aligned first as it affects the front alignment. The violent wobble is castor wobble and indicates negative castor possible from sagging suspension springs. The camber is out at that results in the car following every dip in the road. The camber has to work in conjunction with the toe-in measurement and if the 2 are not correct then you will have problems.
Nov 20, 2013 | Ford Cars & Trucks
Stering wheel shakes at 30 to 40 miles an hour
Put your spare tire on one side of the front. Drive it, if it does not help, replace the spare and then try removing the other front tire. Drive it and see if it helped.
The tire that caused the vibration probably threw a weight or has a broken belt. Have that tire checked and repaired, then have the Tire shop put the spare back in the trunk.
If it is not a tire problem check your tierod ends. They connect both front wheels and if there is a lot of play, you can get shake and wobble from the slack in the frontend.
Sometimes front Rotors can cause a shake when you hit the brakes. If the car shakes without pressing the brakes, then its the tires or frontend.
Feb 07, 2011 | 2004 Ford Crown Victoria
I have a 2004 GTP Supercharged and i get a back speed wobble between 80-90kms and 110 km's per hour. Less than 80km's or over 110km's it's fine. The problem seemed to appeard after i put the summer tires...
chances are a balance weight has fallen off,always dynamically balance wheels and tyres front and rear,dynamically, means up,down and sideways,stops shake and wobble.....
Aug 18, 2010 | 2004 Pontiac Grand Prix
I have a brake pedal judder at low speed, it only starts at under 40 miles per hour,no ABS light comes on and the car has just passed an MOT but I still want to know what it is, any ideas?
Does this wobble the steering wheel or your seat? The difference is very important. If it shakes the steering wheel, you have warped front rotors. If it's more through the car and seats, rear rotors are warped. Let me know please.
Jul 28, 2010 | 2000 Jaguar S-Type
The front end shakes bad at 40 miles per hour on my 1993 ford f-350 crew cab 4x4
You may need your steering realigned, also, make sure you have your wheels bolted on straight. If those clear, get your spindles checked, along with your shocks.
Mar 18, 2010 | 1993 Ford F350
Front wobble after installed new elite 3 tire
Tire was either not balanced properly, or wheel is bent.
Aug 13, 2009 | 2008 Honda GL 1800 Gold wing Deluxe
Wheels in the front of a 1994 ford aerostar shake when coming to a stop from speeds of 40/70 miles a hour, also the steering wheel shakes.
The front break rotors are causing this..
You need to have the break rotors turned - or replaced if they cannot be turned..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 07, 2009 | Ford Aerostar Cars & Trucks
Steering wheel vibrations
It could be worn starting parts, Not ballanced wheel, and broken or worn struts. Start with the wheel getting ballance and go from there if there was no problems before your got the new tires put on.
Apr 07, 2009 | 1998 Volvo S70
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
