Indesit washing machine
Indesit evolution 1100 we10. display reads F-04
  • chrismiller Jun 25, 2008
    same here with the lights flashing and i cant empty machine
I have same problems here too so i would also love too hear how this is solved ?????????
Posted on Jun 25, 2008
Washing machine working until final drain, rinse and spin then 3 lights flashing, door lock, stain removal and extra spin.
Unable to empty machine or unlock door.
any suggestions
Posted on May 17, 2008
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
F12 error code
Dado
Jan 23, 2014 | Ariston Technologies AWD121WH
Washing machine WE10 showing F-08 error report
This is a drain pump failure or overflow condition code.
  • Check the drain hose make sure it is not plugged or kinked.
  • Check connectors to drain pump,pressure switch, and to the control board.
  • Check/clean drain pump filter.
  • Check for drain pump failure.
Aug 16, 2010 | Indesit Washing Machines
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
What does problem F-08 mean.
F08 means the heater relay cannot be activated.
Check all connections to and from the heater the module and the pressure switch.
Hopefully this will cure the problem.
Jan 11, 2010 | Washing Machines
Indesit Evolution 1600 WE 16 Washing Machine with F 05 Display
Get unit to spin and drain. See if any of those are a problem. Check if heating element has a circuit and if possibly an over temp cut out has occured. Normally if a code no. has come up, a certain condition has occured which should be rectified.
Sep 16, 2009 | Washing Machines
INDESIT EVOLUTION 1200 WE125 WASHING MACHINE
Pressure switch not sensing correctly, this being the case, you will need an engineer.
Oct 13, 2008 | Indesit WA 125 Front Load Washer
Washing Machines Logo
353 people viewed this question
Top Washing Machines Experts
