Question about Honeywell 4600g Wired Wand Barcode Scanner
I have a honeywell 4600g barcode scanner which i have installed via USB but i cant seem to make it work. how do make it work... is there software for it..
  • 8 Answers
SOURCE: Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Posted on Sep 23, 2007
SOURCE: QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Posted on Nov 08, 2007
thesuperdude
  • 97 Answers
SOURCE: scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Posted on Apr 02, 2009
  • 34 Answers
SOURCE: I have a Honeywell 3800g Barcode Scanner with a
Most barcode scanners will not use a standard mini-din to USB adapter. You need to replace the cable with a USB cable designed for that bar scanner. Here is a Google shopping result for the cable you need. Good luck!
http://www.google.com/products/catalog?q=honeywell+3800g+usb+cable&hl=en&safe=off&prmd=ivns&biw=1419&bih=695&bav=on.2,or.&wrapid=tlif129971812876510&um=1&ie=UTF-8&cid=1100600390771774037&sa=X&ei=_B94TdetEI6NrQG6p5nuCQ&ved=0CF0Q8wIwAA#
Posted on Mar 10, 2011
  • 378 Answers
SOURCE: What software can I purchase
Microsoft Excel can print bar-code labels. I did this for my office for our stock room and they work with every bar-code reader I've used so far.
Posted on Apr 22, 2011
How do I remove the X from Scanning?
The scanner can only record what it sees.
What you have is a software issue.
If you can not prevent the X from being on the wrist bands in the first place, I would contact Meditech support. to see if the software can be programed to omit it.
Jun 30, 2014 | Honeywell 4600g Wired Wand Barcode Scanner
4600g
Basically you don't need any driver for USB interface,but will take longer time to auto install the driver on certain version of Windows 7.
Jan 08, 2014 | Honeywell 4600g Wired Wand Barcode Scanner
Honeywell 2020-5 suddenly stopped scanning. The lights are on the charger base, but the scanner seems dead.
I guess there is a problem with the base station. Let me tell my story:
I got a 4820 scanner with 2020 base. All worked fine till I experimented with scanning images. After a few images (which I cannot retrieve/receive properly due to lack of software) the scanner seems dead. From time to time a short buzz sounds when triggered, but no light or else.
So I bought another 4820, a slightly different model. Seems to work fine but has to be paired with the base to get the data. Now after pairing this scanner shows the same issues as my first and refuses to scan.
I installed QiuckView and HSM-USB-Serial-Driver on a virtual machine at my MAC to flash firmware to base and scanners. But the base device does not show up in the program (althought it is shown in the USB device table). Maybe I can try on a native WindowsPC ...
Oct 21, 2013 | Honeywell 2020-5B Cordless Bar Code...
Need driver for Honeywell 4600g for motorola ML910
http://download.cnet.com/motorola-surfboard-sb5101-usb/3000-2112_4-70249.html
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.innovative-sol.com/drivermax/
free program, paid update available
if this driver is not right
Jul 16, 2012 | Honeywell 4600g Wired Wand Barcode Scanner
Hello Is there any driver for use this scanner with usb port?. Thanks.
Please go the Honeywell site listed below (as they are the parent company of Metrologic).
The link should take you directly to the software downloads pages for the Metrologic MS3580. The software you are looking for is Honeywell Scanning and Mobility USB Serial Driver...it is 4mb in size.
Please follow directions carefully during installation as these scanners are a little finicky on driver installation.
Please click HERE for the link to the website and then click "software" to be taken to the drivers page.
Hope this helps.
Thanks,
May 09, 2011 | Metrologic Instruments Metrologic MS3580...
What software can I purchase so I may make barcodes with a Voyager Honeywell scanner.
Apr 22, 2011 | Honeywell MS9540 Voyager Hand Held Scanner...
Honeywell 4600g Wired Wand Barcode Scanner Logo
505 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
