Question about PC Chips P23G Motherboard
My windows xp was recently installed again, but now i dont seem to be having any sound at all.my speakers are workinf fine.
  • PC Chips Master
  • 27,725 Answers
Control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Posted on Sep 14, 2010
I recently installed windows 7 ultimate on my pc which earlier had xp installed. i am unable to get any sound from my speakers creative inspire 5200 5.1...windows recognizes my speakers but coudnt install...
its not the speakers. it may be that your sound card driver is not installed so try downloading the drivers from the laptop support site and then try connecting your speakers.
Jan 04, 2011 | Creative Labs Inspire 5200 Computer...
Just installed windows xp and my speakers dont work
if your pc came with a motherboard cd then insert this cd an auto play will pop up run the cd from there and select all drivers everything will be installed hope this helps if it doesnt work then check the jack the speaker goes into the green jack.
Mar 08, 2010 | Linhof 4x5 Master Technika 2000 Body -...
Sound problem
if u cant install the sound driver just buy a USB sound adaptor and connect it to the USB port and connect the speaker sound jack to the sound port in that....u will have sound....also keep in mind that u " may" have to disable onboard sound in BIOS
get it in Ebay or goole it to locate a place near u
Feb 23, 2010 | Compaq Presario 700 470024-192 Notebook
I recently got a new computer & it has windows
If there is not a dedicated port for the sub, you are out of luck. Unless - the MLI sub can serve as the splitter
Jul 24, 2009 | MidiLand MLi 450 Computer Speakers
Distorted sound after installing software plus GigaPocket issues
Have you physically disabled the onboard sound in the BIOS? By doing this I think most of your other hardware/software would default to the only audio device (your SB).
Post back if you've already done this and I'll see what else I can dig up on your hardware and possible conflicts.
Mar 03, 2009 | Creative Labs Computers & Internet
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
No sound devices on my sony vaio VGN-CR322H laptop
Pl check the whether all driver from OEM have been installed including MB and try to reinstall the driver it should work fine. or reinstall the SP2 for win XP. then install the OEM driver again, this should work, else there might be hardware problem.
Aug 20, 2008 | Sony VAIO PCV-J200 PC Desktop
Sound
there is nothing wrong with the speakers.
install the audio drivers from the mother board cd
Jan 02, 2008 | Balance CM2017 17" Monitor
Sound
first try using windows system restore, which makes windows appear like it did before your problem. do this sequence: start-all programs-accessories-system tools-system restore. run it and look for a calendar date before your problem. If you had system restore turned off, the solution may be long and painful and I simply do not have enough info to get you started in this case, other than to attempt a re-installation of windows XP.
Aug 17, 2007 | Microsoft Windows XP Professional With...
Speakers are not being recognised
i would like to know if your on board soud or sound card is not being recognized by your system? as far as i know speaker will not work if your sound device driver is not installed. so maybe theres nothing wrong with your speakers. try to go to my computer properties go to system device hardware and see if there is an yellow exclamation in your sound device. if there is, update the driver using the provided cd from your motherboard, if its on board sound device. but if its a sound card, update the driver using the cd provided from your sound card. but if your sound device is ok and there no yellow exclamation, probably you hooked your speaker connector to the wrong jack. it should be the color green one. try and good luck
Jan 20, 2007 | Generic Memory 2-Piece Amplified...
PC Chips P23G Motherboard Logo
41 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
