Question about LG 42LC2D 42 in. LCD HDTV
My LG t.v is making a horrible static like noise and has white lines through it can u give me any reasons why?
    Genius:
  • 1,622 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Take care.....
Posted on Sep 14, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
My lgis making a horrible noise and is now shoeing an e1 code dishwasher
The LG does suffer from "poor quality" motor that causes this type of noise. The main motor and pump assembly is common to give this type of problem. The pump seal leaks a small amount of water that gets onto the front bearing and causes a "grinding = humming" noise. This can be easly replaced once you have the bottom off and dishwasher on its door. The motoe has 1 screw in the back holding the motor to the bottom and two rubber seals for the water pump in/out into the washer. Just pull and move motor and pump assmbly and it comes free. Replace with a new motor and pump assembly...
Nov 18, 2011 | LG LDF6810ST Stainless Steel Built-in...
I have a JBL home theater system that is about 8 years old. The sub woofer is independently powered with an ac line and now intermittently has static/white noise that comes and goes without any apparent...
Its probably electrical interference. You are better off replacing it, or borrowing a friends sub and hooking it up. Just to make sure it's not your reciever or any wiring.
Mar 14, 2011 | Audio Players & Recorders
My Turtle Beach headset makes a horrible popping static noise and cuts in and out randomly throughout game-play. I have a wireless router (LinkSys) and an LG 32" Flat Screen TV. Is there a way to cancel...
Plug the USB in the front of the xbox360 the USB plugs are shielded in the front that fix your problem it fixed my problem my Dlink wireless router makes it go nuts with that ear piecing popping sound when i plug the usb anywhere else.
Apr 06, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
Abit KN8 ultra chipset coller
Try cleaning with compressed air.But i believe the bearings in rthe fan are bad..replace new.RichardM69
Nov 30, 2008 | Abit KN8 Motherboard
Hissing sound in the middle of videos Logitech Communicate STX
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Sep 15, 2008 | Logitech QuickCam Communicate STX Personal...
LG TV Making Bad Noise
have u tryed new cables for sound 1st
Feb 03, 2008 | LG 42LC7D-UB Television
LG 42LC2D 42 in. LCD HDTV Logo
243 people viewed this question
Computer Repairing
Computer Repairing
